  • Replies 104
Sorry to hear man. I had the same done to my Swift GTi when I was younger. It was in a holding yard after a minor accident and it was stripped bare. they even stole the battery and intake!
I hope it goes well *fingers crossed*
It was nice to finally meet you at Macca's on the saturday with Anna and Tinks, Just a shame under these circimstances ;)
Was nice to meet you and your brother Dan, as Jess said - shame it wasn't under better circumstances but best of luck getting the cars fixed and hopefully we'll see you at SnS..... :D
Was nice to meet you and your brother Dan, as Jess said - shame it wasn't under better circumstances but best of luck getting the cars fixed and hopefully we'll see you at SnS..... :)
was nice meeting you too!
Hopefully I'll have a car for the sns if not I'll come down and say hi...
Cant believe Ive just lost my car.... :( :( ;)
Surely you can sell the parts that are usable? Unless the insurance took the car? Arent they suppose to give you money if they do?
:( to you.
Can I have your rear boot battery plate thingy? :(
My GTST has been declared a total loss as the damage bill exceeds what the insurance company sees as viable to make repairs.... :(:(
BUGGER :(
Sorry to hear that Dan - you must be devastated all over again..... hope things go better for the GTR.
didn't read that taxi bit in the first post til now...
if you know which company it was, ask for their help... any recently damaged taxis? plus they all have cameras in them now... could be something?
Sorry to hear Dan, looked like a beauty too! I thought I was shit out of luck when I came back to my car at 6pm on a Saturday after a Wedding Reception finding some c**t has smashed my passenger front window and nicked off with my 80GB Ipod Video and radio face which i ended up finding scratched a few meters from the car. I was ready to sell my car, but after a week off the road sorting out a new glass, the first time i drove it after that I wanted to keep it and it became a distance memory!
Best of luck mate, hope these destructive thieving scum get whats coming to them!
    • I have done smoke test and can’t see any leak on high or low side.   checked pump and fluid can flow through. Removed the high pressure from steering and did smoke test and same on low side, no leak.   puzzled. Thinking why if it was all ok it suddenly went as car was off road for a year. Don’t want to disassemble pump yet as i can see fluid / air( compressor) can flow through with no issues
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
