i have a screamer pipe on an external gate on my car. yes it is very loud, and yeah i guess it sounds like a jet. i hope its not 10k fine cause that would be very bad. if cops are around its not a problem because external gates come on big turbos so they open up late. mine opens at around 4500 revs so its quite easy to drive without it openning if you want. and yes you can pipe them up, they pretty much go straight back into the exhaust just before the cat.
Hi guys, on a turbo car, the rapid rotation of the turbine "cuts" up the noise waves. So if you run an open exhaust (no mufflers) the noise from the turbine it is not as loud as that from wastegate. There is no cutting, so the noise is substantially louder (more than 10 db) from the wastegate.
I have never seen any significant horsepower loss from plumbing the wastegate back into the exhaust, if it is done properly.
So it's just noise for noise sake, no performance gain.
define "properly"
i am planning on piping up the gate when my car is rego'd. the screamer pipe has a flange on it and my front pipe has has a flange that has been covered just in front of the cat. i assumed that all it needed was a pipe going from one to the other.
Hi aybee, "properly" means;
**Joins the main exhaust more than 300 mm from the turbine
**Has allowance for differential expansion (slip joint or flex pipe). Otherwise it will crack due to the different expansion rates, the main pipe expands as soon as hot exhaust, via the turbine, hits. The wastegate pipe doesn't get hot until the wastegate opens. Result = constantly cracking joints. You can help this by wrapping both pipes together with exhaust wrap.
**Has good flowing joints, not a right angle, as I have seen more often than I would have thought possible.
**Is of the appropriate inside diameter.
**The pipe from the joint onwards is of sufficient inside diameter.
Basically standard good sense that any decent exhaust shop should know.
Hope that helps
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
    • Glad it eventually came out Duncan!   I believe that might be 040. 044 is the inline pump, so has screw fittings in and out. 040 is more just drop it in fuel and the bottom is "open" (mesh) from my memory
    • well mate, while I hear your pain, turns out I don't feel it this time! Must have been a bastard of a job crammed into the boot The tank was very empty (probably pumped out, not dropped and drained because there were some fumes still) and in very good condition internally. I'm sure he never ran e85 in it I don't know what the hell Nissan's fuel tank engineers were thinking about their clipping system, this hanger was really hard to get moving but came out in the end All looks very good (as I'm starting to hopefully expect) and Matty was right it is an 023 (044) bosch which should be plenty for the injectors and turbo
    • Saturday 8th February 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Thursday 6th February 8pm. Supp Regs: TBC Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. email [email protected] To compete in this event you will require A valid  AASA General Speed licence or (Day license is $35.00 via the AASA Website) MA Licenses are no longer accepted by AASA https://aasa.com.au/ A helmet, long sleeve clothing and it is reccomended a 1KG mounted fire extinguisher (But not Mandatory). Further details within Supp Regs Above. You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Entry Link >> https://www.sauvic.com.au/entry/deca/20250208 Entry List: 1. Martin Sullivan 2. Richard Hicks 3. Warren Clark 4. Luca Stamatescu 5. Tony Buckland 6. Min Chan 7.  8.  9. 10.  11. 12.   13. 14 15.  16.  17.  18.  19. 20.  21.  22.  23.  24.  25. 26.    Reserve list 1.  2.
