  • Replies 121
Speaking of gay shit.
Surely spacing the wheels out that much would ruin the suspension geometry. Looks like it has downs syndrome.
in a rational world yes that is gay. but in this case you are dealing with bosozoku mentality... think rat rods in america. defies logic, yet is still considered cool.
As much as you guys have ragged on them..
Im still goin to be getting 205's on my R32 GTR rims..
and guess what?
Ill still be happy with them.. even after reading this thread..
:whistling:
Edited by GTS4WD
we spell it tires over on this side of the pond :)
you're canadian! :cheers: you should spell it "tyres" like the rest of the colonies... we speak english, not american.
  • 1 month later...
  • 4 years later...
On my current car, i run 225/40/18 on a 9" rim. We tried stretching a 215/40/18 on there but it was a no-go as it popped off. Needed to be a 45 profile for it to work.
The 215/45 will fit easily on a 8"
any pics of this. i have xd9's 18 x 9'' front 18 x 10'' rear was thinking 225/40/18 front and 245/40/18 rear. with some good tyres
thoughts people???
thread revival FTW
Edited by Nick033
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
