  • Replies 121
i do it for cost and so the wheels sit better in the guards
ive got 205's on a 8.5" on the front and 225's on a 9.5" for the rear.
looks depend on the tyre also, previously i had a set of dunlops that were 235 on the rear and they looked like they were stretching more than my current 225's
I've also had the same thing with dunlop and bridgestone 235/45/17's being quite different on my 9in rim. The Bridgys look stretched and the dunlop sat square.
I like the look of it and the less sidewall flex.
from a grip standpoint, your getting less tread on the road though
Not exactly true. The tyre width does not determine the size of the contact patch. All else being equal, a 225 tyre will have the same surface area touching the ground as a 245 width tyre.
Huh? Am I missing something? skinny tyre=less surface contact, fat tyre=more surface contact?
I always had 235's on 10.5" rims. Same reason as said before, any bigger would rub.
That's pretty good fitment mate.
Any chance you can explain?
With your 14x10 Longchamps, you've dumped it till sparks off man holes and with as much camber as you can dial in the tyre still hits the guard, you need to stretch. This is where the fad all started ladies and gentlemen.
And here it is, 195/60/14 on 10inch.
I had another read of the post, and in the context it was posted I'm probably wrong. With an ultra-stretched sidewall, that doesn't flex as much as one with a "proper" fitment, the contact patch will be smaller.
Which is probably why didn't reply to his post the first time......
But if you run two tyres of different sizes on rims that they're "suited" for (like say a 215 width tyre vs a 245 width tyre on a 7.5" wide rim) then the difference in contact patch between them is minimal.
right australian manufacturers know everything...
ahhhh this is why in germany cars such as porsche and mercedes come with stretched tyres from the factory....
that's right, it's PORSCHE that know nothing., ah keyboard warriors were right the whole time, should've known...
"Imagine driving on to a glass road and looking up underneath your tyres. This is the example contact patch (in red) for the situation I explained above. The narrower tyre has a longer, thinner contact patch. The fatter tyre has a shorter, wider contact patch, but the area is the same on both."
Because you now have more space the weight is less per cm so the contact patch decreases. Of course all sorts of factors change this, eg tyre pressure, how much its stretched etc.
Stolen from http://www.chris-longhurst.com/carbibles/tyre_bible_pg2.html
They might stretch them but its not ridiculous stretch eg a 195 on a 9.5" rim.
Edited by Rolls
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
