This is an excerpt from the G35 2003 ESM that also applies to the V35.
It outlines what maintenance and preventative inspections are recommended to be performed and at what intervals.
ma1.pdf
Edited by -= SKiZO =-
https://www.sau.com.au/forums/topic/173808-maintenance-schedule-for-the-v35/
No worries, not sure if many know about this new v35 forum though so maybe we need to advertise! From the time I decided to change cars till i actually got it in my hands was about 6 months, so spent that time researching as much as a i could, i guess in a way to confirm that I really wanted this car. But so glad I did get it. I get the info from lots of places but alot of it comes from g35driver and the US guys have been really helpful.
  • 3 weeks later...
There is a folder on g35driver.com with the whole manual. This is the link for people to download:
2003-2004 G35 Coupe BOTH Automatic and MT Transmission
http://rice.sightless.net/03-04coupe.zip
2005-2006 G35 Coupe BOTH Automatic and MT Transmission
http://rice.sightless.net/05-06coupe.zip
  • 1 year later...
My maintenance is due and read the guidebook. It says to replace the in-cabin microfilter. Sounds like it is unnecessary. Has anyone ever replaced it?
changed mine last year. you can get it from a nissan dealership for around $110 and replace it yourself - it's a pain to do it though as you have to remove a lot to get to it. it's way cheaper if you can get it from the US, i think it worked out to be about A$25 including shipping to a US address. not really necessary to replace it but it can get quite dirty after a while and a dirty filter can give off a bad smell when you switch on the aircon.
I know it is a little old but those files do not work, is there any chance that you can update them...
Perhaps if you have a copy of them you could upload to www.megaupload.com, it is free for basic use!
Would be a great help if you can assist.
They get really dirty quickly and clean air is so lovely. There are normally pictures of how they look at Nissan Delearships, they are not unlike a standard paper filter but they are treated for microbiological contaminent particle trapping.
I took a look quickly at G35 and there is a link to a website that you can download lots of different manuals, unsure of the actual quality as I am still downloading.
This is the site and everyone should take a look...
http://psedog.com/cars/fsm/g35/coupe/
Use the links on the side for different cars.
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
