hey guys just wondering how much you guys have paid or what a good price is to get a afc neo installed in my 33.
and also how long should the dyno tune take to tune it??
any help would be appreciated, thanks.
https://www.sau.com.au/forums/topic/173827-afc-neo-installation-costs-and-tune/
Yup cost i got quoted from a top tuner was 330 all up including the tune.
150-250 is normally for the tune..
And i wanted afew other tiny little bits done.. so think it was about 300-330
Im going install one in the next two weeks.. :bunny:
Tune should take 1.5-2 hours max.. nothing more.. unless its got problems
Wont take that long Sidd, SAFC is quite simple to tune.
It only controls the fueling (SAFC stands for super air flow convertor - it literally takes the airflow meter signal and converts it a given percentage higher or lower dependant on the given RPM).
Unless the Neo is different from the SAFCII, it definitely shouldnt take long to tune at all, maybe 10 - 20 mins at most?
I spoke to swann180 last night.. he tells me it took him only 20 mins to set up everything correctly.. think he did it himself
however we both were drunk, and we didnt speak too much about it... hahahah
But most tuners say it should take 1 hour max.. 1.5 at most!!
So if its 1 hour, im sure 20 mins will be just getting the settings correct, and the rest will be fine tuning things
yeh 1.5 max hey. yeh hope so.
so that will be around the 450 mark fitted and tuned they will want to charge me i am guessing.
down melbourne is probably the cheapest way to go but then theres the drive down costs as well
Hey sidd, sobered up now ;) so my opinion may make slightly more sense now :D Oh and I didnt set mine up, Dale from Castle Hill Exhaust did.
But yeah basically an SAFC only controls airflow, and does so by correcting the signal sent from the airflow meter. Unlike a full management system it has no control over ignition timing.
Also, an SAFC doesnt take engine load into account, only RPM.
Basically it just increases or decreases the amount of fuel being injected into the engine at incremental RPM.
It really shouldnt take very long at all to set up. All your tuner would need to do is a dyno run, mapping AFRs on the dyno sheet too.
Seeing where the engine was running too rich and running too lean, they then would just add or take away fuel where required till they have the desired fuel curve, and viola thats it.
It really shouldnt be costing very much to set up and definitely shouldnt take an hour on the dyno to tune it either.
In 1.5 hours a good workshop should be able to install *and* tune it to be honest, its really not an overly complex task and the way the unit functions is quite simple.
If you are in any doubt, ask the tuner what *exactly* youre paying for, and what exactly they need to do.
Hope that helps :D
Hi Cliff,
The fitting of the afc is about 2 & 1/2 hours ($192.50 @ $77 p/hr) and the dyno tuning is $143 p/h. As this is a bit of an unknown, I can't give you a quote on it.
thats the quote that they gave me.
so does anyone around here know the place in sheperton that does dyno tuning?
been told that they are good.
any one got any feedback from there or any one got the email address or number>?
even there name would help?
thanks.
been told that websters is not so good in albury
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
