Hey guys I got given this catch can and yes before you ask I have done a search, just wondering why it has 3 ports out of it, I supose its not a catch can but a oil sperater, anyway what do you guys think and what is the nipple at the bottom for? should I turf this and get something else?
https://www.sau.com.au/forums/topic/173855-another-catch-can-question/
two on the top for "intake" and bottom for releasing gases and such out I believe. most guys just run a tube out underneath the car.
wont all the oil just drain out of it then and if you run the pipe up then down the air wont go thorough the oil would it?
Two of the ports are for as discribed the top of the covers, 1 side for the top of the covers the other plumbed back into the intake, the bottom one is for a drainage of oil. There is a big thing about baffling inside the can too to make it well more effecient in its design of what its for. Usual trick if you can open it up and place steel wool inside a stocking then place the stocking inside the can will help with its efficiency in a big way
Plenty of topics on this search (catch+can) or oil/air seperator for more information
Cheers
A
Unless your car is blowing a large amount of oil my suggestion would be to plug that lower hole.
just run it as a std catch can(with the wool inserted) and drain it from that plug if it starts to fill up
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
