  • Replies 113
no no, a 33R is the go....
seems VERY strange that they wrote it off hey... VERY strange!
maybe ask them how much to buy the wreck ? you get your 37k back, and buy the wreck for maybe 10-15.. instant profit!!
then sell it and buy a 34R with extra cash from your old lady!
Hehehe Strich9ine , I won't bother getting the wreck, if i have to repair it , It will cost me 18k, that's hell lot , I better get other car w/o accident history.
Yeah it takes them around 2 weeks and there is no sign of the parts coming from japan, and it's hell exp to repair r34, I wonder why.
  • 3 weeks later...
Updating the thread, around 2 weeks gonna finish :)
The guy offered me to paint the rest of the body for 900 is it abit expensive? roof, right hand panel , door, left hand part ( on top of the window part)
If the price is cheap i'll go with it to make my car mint
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
