My Car WRECKEDDDDDDDDDD
3R1K
 Share
Any good panelshop will be able to colorcode the paint 100% perfect. Wilkinson are very good, they did my bosses 03 WRX when someone rear ended it, took them 1 week to fix the boot/rear taillight and rear 1/4 panel
Shoudlnt take them much longer than 2-3 weeks, if they can source the parts they need locally.
  • Replies 113
Really? 2003 WRX? wow is it good ?
Did you see my pic? if there are some scrathes on the bonnet , driver windows will they repair it? the scrathes was from my rolling door glasses just fly (I assume) and scratch
Originally posted by eriktufa
One more thing memphis
If after the repair I can see the colour mismatch between the old paint and new paint will I able to ask for full repait?
No
memphis - but the painter has to take into consideration variants.... not every black skyline is EXACTLY the same... slight slight differences you would only notice if a whole panel was painted that. The painter should be able to match the paint perfectly
  • 1 month later...
they wrote it off
shit that aint good.....
at least you have insurance....
did you have it insured for the amount you paid for it or a bit more.
are you going to get another R34
good luck and let us know how you get on
If I had an accident in my car I would want it written off rather than repaired. I've known a few people that have had their's repaired after major accidents and the car is never the same. One was a t-bone, she drove into infront of someone and they hit head onish the other was he got hit from behind.
heya guys, I do want write off cause it feels different when u drive an accident car, possible I'll get another r34 , hunting for car again.
MrSnrub -> 3 months, it's not long
ReVN211 -> I insured it with the same amount when i bought it , I should insured more damn :)
Yeah it sucks, I was going to get stuff to dress up my r34, and i have to get other.
memphis -> call famous car insurance, and talk to tony if you want
Well Shacks Holden had another black R34 in after the one you bought :)
THink it may be sold but, havent seen it there in a while.
i always found it ironic seeing an R34 Skyline with Shacks Holden number plate surround thingy.
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
