41 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
jurule,
Have a read above as the R33's are not a simple drop in like the R32's.
Its up to your self if you think its worth while or not. The PFC has its benefits with the downside of an external vct controller.
A vct controller still has to be sorted.
The problem with the emanage is tuners willing to play with them. They are not a simple plug with what I've been led to believe have poor documentation.
  • Replies 85
No problem. :)
Do consider that a VCT controller still has to be sorted out. This is a little project in my spare time so it won't be completed over night.
The Rb26PFC without VCT works perfectly fine in the R33; its only the VCT controller that has to be sorted. :)
So... Its up to you if you can hang off for a little until the VCT controller gets sorted.
With VCT off the RB25's mid range is a little lack luster.
lol... Yellow Galliano is much more appreciated.
No need for a motivation incentives.. Comes down to limited time at this very moment as I have to get mine back on the road; I'm fabricating the dump pipe, inlet piping etc myself in spare time.
Won't be too long. I've updated the thread starting post. :)
  • 4 weeks later...
For the R32's there's no problem. For the R33's really there's no problem either BUT at the moment I still haven't got a VCT controller, which I won't be doing until my own car is sorted with respects to needed a new headgasket; I attempted to reuse the old metal shim but bah bugger leaks. :down:
    • Lowest point on the car is 105mm now, so just legal and hopefully high enough to clear After paint, much happier with how it looks Before looked real 😝
    • I'll measure it up at the lowest point later and post it up Currently painting, with the oven all warmed up to 93°c
    • How much clearance is under the car? We have speed humps being added everywhere around me. Faster than they fix the potholes, thats for sure.
    • After some googling of various websites IRT the best ride height for correct geometry I ended up going,  hub to guard, 330mm in the rear and 345 at the front, these heights came from Flyin' Miata in the states as what they recommend (13" rear, 13.5" front) The rear needed to only come up 5mm, but the front came up 15mm Overall it is around a 25mm drop from OEM ride height, doesn't look all 4x4, and hopefully should be enough height to clear those pesky speed humps I have lost around 0.5° camber on the front, and around 0.2° in the rear, I have no idea about what it did to toe settings so I'll look at a new alignment next week to get it set up how I want, zero rear and a little in at the front I've also stripped the new intake and am currently cleaning and preparing the alloy for some paint, I've headed into work to do it as I can use the ovens in the soils lab to cure the wrinkle paint at 90°c Jackie has banned me from using the oven at home for stuff like this....🤣
