sorry to hear it is a write-off mate, but you are probably better off in the long run. What about an M35 Stagea? Not bad and cheap as chips for what you get
http://www.prestigemotorsport.com.au/modul...hp?StockID=4379
  • Replies 73
Guy, Synergy on Main North road currently have a GT350 V35 coupe and a GT300 V35 sedan if you want to drive one. They are really nice, but gutless as hell. You can buy TT kits for them though :pirate:
