Tommy Kaira bodykit
Front Bar
Side skirts
Rear pods
Rear wing
Tommy Kaira Interior
Tommy Kaira Gearknob
Recaro Seats front and rear
Fully trimmed as Tommy Kaira
Body Kit badged Tommy Kaira
RB-26DETT
48 000 Km's
Trust Full 3" stainless exhaust system
Trust AirInx Intake system
Trust Intercooler Kit
Trust Oil Filter Relocation Kit
Trust Oil Cooler
Trust Guages in glove box x 2
Trust Turbo Timer
BBS LM Evolution Wheels 245/45/17 rubber
TOKICO adjustable suspension
OS-GIKEN Twin plate clutch **new**
Regular services
Owened by mechanic
Immacualte
2nd Mature Owner (1st owner in Australia, Personal import)
$39 990 FIRM (No hagglers) (drop email for pics)
https://www.sau.com.au/forums/topic/17391-tommy-kaira-special-r-32-gtr/
I think you'd be better off posting some pics in this thread. From personal experiences posting as much information as possible generally filters down enquries to those who are serious about buying. Hope that helps, good luck :D
Rick
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
    • Can't see that being a thing.
