  • Replies 140
Hi, Sorry mate I didnt see you, but my Girlfriend did.
"Hey that PULP guy just flashed you, did you see him?"
Saw your tail lights haha
Cheers :pwned:
JK
You guys are lucky that know eachother,
I saw an other silver 350GT in Burwood sydney, yesterday night.
I don't know whether he is on form either???
Cheers :blink:
JK
HAHA! :O love the sound of your exhaust BTW, will have to hear it up close some time! I'm thinking of getting a Borla but not sure if it is too loud inside or droney. My last car was way too droney inside, how is yours?
HAHA! :D love the sound of your exhaust BTW, will have to hear it up close some time! I'm thinking of getting a Borla but not sure if it is too loud inside or droney. My last car was way too droney inside, how is yours?
I reckon it sounds porn! Next time u see me pull me up and i'll give your ears an orgasm! The system is quiet putting around town... Lambo on full noise!
JK
JK
Jaik
Next time you are in Ozzy Park drop in and see me and Pulp so we can both check it out.
Paul
Our rules state that if you have Xenons fitted there must be a headlight washing system too as I think they cause glare if dirty.
In 2 years of driving the V never had a complaint from oncoming cars.
The std Xenons are great
yeah no worries lads, I do work for a company on king edward road. PM me your details, I'm in the area in the morn and late arvo
JK
Hey nice to see you JK the other day :cheers: Be good if you can drop in, we are on Howe st, look for the two V35s! :down:
I thought i noticed that the 07s did have a pop up washer? New 08 WRXs have Self-levelling Xenon headlights with pop-up washer.
See the little things under the headlights?
http://www.cubicleofdoom.com/uploaded_imag...s4_3-760184.jpg
http://www.autoclub.com.au/uploaded_images...b320-790164.jpg
Maybe you've just never seen them pop up!
JK
JK
well that does not gell at all with the nissan owners manual i received with the car.
i have just read the headlight section and it details the xenon headlights (if equiped)
so they must be compliable in aus.
one v35 i looked at had already been complied and it had xenons installed.
the manual looks like it has been printed and written in australia
I just checked the nissan website - http://www.nissan.com.au/z/exterior.asp
Looks like the Z has pop up washers aswell.
It is very possible that the law has changed recently, and therefore cars that were complied when it wasnt the law are exempt from it.
JK
JK
That law has been aplicable for a long time.
That's why R34's had to have thier Xenons removed as well due to no washer system
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
