  • Replies 140
Hi, Sorry mate I didnt see you, but my Girlfriend did.
"Hey that PULP guy just flashed you, did you see him?"
Saw your tail lights haha
Cheers :pwned:
JK
You guys are lucky that know eachother,
I saw an other silver 350GT in Burwood sydney, yesterday night.
I don't know whether he is on form either???
Cheers :blink:
JK
HAHA! :O love the sound of your exhaust BTW, will have to hear it up close some time! I'm thinking of getting a Borla but not sure if it is too loud inside or droney. My last car was way too droney inside, how is yours?
HAHA! :D love the sound of your exhaust BTW, will have to hear it up close some time! I'm thinking of getting a Borla but not sure if it is too loud inside or droney. My last car was way too droney inside, how is yours?
I reckon it sounds porn! Next time u see me pull me up and i'll give your ears an orgasm! The system is quiet putting around town... Lambo on full noise!
JK
JK
Jaik
Next time you are in Ozzy Park drop in and see me and Pulp so we can both check it out.
Paul
Our rules state that if you have Xenons fitted there must be a headlight washing system too as I think they cause glare if dirty.
In 2 years of driving the V never had a complaint from oncoming cars.
The std Xenons are great
yeah no worries lads, I do work for a company on king edward road. PM me your details, I'm in the area in the morn and late arvo
JK
Hey nice to see you JK the other day :cheers: Be good if you can drop in, we are on Howe st, look for the two V35s! :down:
I thought i noticed that the 07s did have a pop up washer? New 08 WRXs have Self-levelling Xenon headlights with pop-up washer.
See the little things under the headlights?
http://www.cubicleofdoom.com/uploaded_imag...s4_3-760184.jpg
http://www.autoclub.com.au/uploaded_images...b320-790164.jpg
Maybe you've just never seen them pop up!
JK
JK
well that does not gell at all with the nissan owners manual i received with the car.
i have just read the headlight section and it details the xenon headlights (if equiped)
so they must be compliable in aus.
one v35 i looked at had already been complied and it had xenons installed.
the manual looks like it has been printed and written in australia
I just checked the nissan website - http://www.nissan.com.au/z/exterior.asp
Looks like the Z has pop up washers aswell.
It is very possible that the law has changed recently, and therefore cars that were complied when it wasnt the law are exempt from it.
JK
JK
That law has been aplicable for a long time.
That's why R34's had to have thier Xenons removed as well due to no washer system
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
