I checked my docs and you may be right, there is no reference to the fog lights in the CIN but the Xenons are in there. So not sure if these definitely needed to be done, but were anyway and I got the attached doc from compliance too.
just went out to the car having read this document for the first time (don't know why i didnt read it earlier??)
took me 30sec to:
- open the door
- take my key and pop out the little plastic cover offthe back of hte stalk
- the little white plug had not been cut, but simply unplugged.. so i plugged it back in
- re-installed the little plastic cover
now i have foglights!!
i'm going to get myself a set of nice halogen H4 bulbs (the high-intensity kind that are a whiteish colour but not HID) and swap them over someday soon, and while i'm at it i will replace the parking lights with white LED wedge globes
  • Replies 140
pics of WAZ's lights on progress :cheers:
front of car before I started :P
now it comes to bits ( fairly easy to remove if you take your time.)
headlight assy.
HID ballast - look closely thats how the halogen lights are done (the plug was chopped!)
HID plug was intact and tucked out of the way..
bit hard to see but there is a blue light there (light is on and warming.)
then it all goes back together :)
well maybe the fog light switch also turns on he park lights
so normally both should come on, but with the fog light out only 1 coms on so it looks like its switching backwards..
mate, take the palstic cover off, it takes literally 30sec and see what you have in there..
Hmm, weird thing with mine is when I turn the centre switch on the stalk my park lights come on, so I assume that they re-wired it to there?
So basically there should be an extra spot for the fog light to go?
Yeah mine too
Yeah mine too
Park lights and high beam come on when I turn the switch. Doesn't appear to be foglights, it's the same one that lights up when I use my high beam. Maybe the integrated foglights are for the sedan only? Can't see where the foglights can be installed in the housing.
took me 30sec to:
- open the door
No worries, cool. Good going with the Xenons too. Much better than anything aftermarket.
Nah mine is still intact! ??? I'm definately putting aside a day to pull the bumper off, had a look with the tourch and I think I could just see that the HID balast are still on the back of the headlights! Hopefully just a matter of re-wiring them.
If it's any help, not sure if the coupe is radically different, but I know on the sedan you don't need to pull out the whole bumper and the headlights. You can do the job with jacks/hoist by pulling off the front wheels and the plastic guards in the wheel well and underneath. May be easier for some this way as you don't have any alignment issues putting everything back.
Hey check what globes you have, should be the H4 type where the high beam is, or maybe the wiring has been modified at the back of them.
Ok took one side of the inside of the wheel arch off, and I can see a silver unit low down which looks to me like a balast (think it may be part of the fog light kit I have). It has two sockets on it, one that goes to the fog light. There is a cable near by with the compatible plug on it just wrap up in the corner, fits perfectly into the other socket, this is the same on both sides of the car.
Also there is a small grey looking balast on the back of the headlight assembly which has a plug that has been cut, the same as the post from Chris earlier.
Chris, with those red wires that were cut in your pictures, did you cut that yourself from the standard wiring (globes)? I'm just not sure where to join the green & black wires that have been cut to?
Cheers!
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
