Hey guys, ive got a 94 R33 SKYLINE, and when wot, after around 4500-6000 rpm, the car may give me a sudden jolt for a split second, and then go again, then maybe another 1000rpm and itll do it again, this is when im giving it WOT.
What exactly is this im experience, i think its surging but cant be sure
its an r33 gtst (series 1 rb25det)
mods:
3"exhaust to split dump pipe
FMIC
apexi pod filter
stock ECU
boost tap running ~12psi
i have a bosch 040 pump aswell, that has yet to be put in.maybe the car needs a tune now?
Could be missfiring? whats your plug gap?
Id put in the new pump and check again.
Also how much fuel was in the tank
Very Much sounds like Factory fuel/boost cut Mine did it at about 10psi with the stock computer....my head nearly hit the steering wheel at 4000rpm.
Stock ECU + 12psi = thats your problem
Back it off to 9psi and you'll find the problem will go away.
Just the normal issue when using a stock ECU. Furthermore, you should not be running 12psi on the stock turbo :thumbsup:
Alright, ill try that and see what happens:), thanks guys.
Is it a limitation of the stock ecu, and should i get the fuel pump installed anyway?
Um...my coils are gapped at .5mm to stop the missfiring, which i knw sounds ridiculous, but its the only way for it to stop!.
Ive since ordered splitfieres which should be hopefully arriving soon.....will gapping back to 1mm with the splitfires increase performance on the same boost?
Can someone explain the surging to me?
I am having real problems with my car at the moment is freaking me out i was just meant to go to work in chatswood and turned around and went home i was scared! I have r33 s2 stock turbo @ 12psi mech controller, fmic, turbo back zorst, pod. Its been fine pretty much had it at 12psi for over 6 months. But it gets this sort of stuttering during acceleration/spool, typically when i DONT put my down enough for high boost, which can be REALLY alarming sometimes and the car jolts. Its freaky. It only got serviced 2000km ago. It happens mostly in 2nd, but a bit in 1st and 3rd and can kinda tell some other times too just alot more subtle. Its also idling a tiny bit funny i think.
I was thinking my fuel pump, its stock and car has 99k kms? Now im thinking afm? Or boost controller? I dont know. If my 12psi was a problem logically i would think i'd be experiencing the problem max boosting but thats not the case in the least.
Xizor - AFM.
take it off, clean it with electronic contact cleaner.
You can also use degreaser.
when I did mine, I only had degreaser.
so I took it off the car, degreased it, washed it out with slow running water.
Got the wifes hair dryer and dried it out completely.
put it back on the car and it was fine.
Some people also have a problem where the internal connectors have broken off and need to be re-soldered. that is also easy.
but try the cleaning first.
if you bother to go get electrical contact cleaner, you don't have to wash it out and it dries by itself.
you can probably find it at places like Tandy, dick smiths or Jaycar.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 馃槈. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 馃槏.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 馃檹 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 馃槈. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 馃槏 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
