For me it started nice and early at Maccas Berwick then off to the Village Green and then STI at the Docklands before we even headed off to Heathcote. It was a good but small turn out compared with last year. There would of been around 20 to 25 cars in the convoy on the way up. We got there to find a lot there and cars were still turning up after lunch.
I met a lot of new people witch is allways good. And maybe some new members in the making..
A big thanks to Heathcote Park Raceway ,The WRX guys and all who had a hand in putting this together.. :(
If you have any pic put them up....
Cheers
https://www.sau.com.au/forums/topic/173931-drag-day-wrap-up/
  • Replies 59
I owe VSP3C $20 but u had left before i got back. PM me ur bank details dood.
btw good day...I finally worked out how to launch my car...practiced all the way home. LOL
tried lots of things...in the end some good drag radials would have been the go.
First time at the drags and blew the turbo down the track.. high boost on a ceramic turbo a big thumbs down! still very new to the turbo scene
Meet a lot of new people and beautiful cars which was fantastic and I did like to say a big thank you to those that helped out with my car, much apperciated
A great experience all up, cheers David
Well, I'm sorely disappointed at my results, but besides from that, it was a great day.
The two quickest cars were the Harlequin R33 GTR with a high 10s pass, and second was REXNFX I believe with a high 11..???
Hey David
Did the car drive home alright? Or did you need to chuck it up on the trailer?
Had a great day, thanks to everyone who organised it. It was a good turnout and I got heaps of runs in.
Found heathcote to be a weird track though. At Calder, for me to run a 12.9 i was getting 2.2 60'. At heathcote to run a 12.9 i need a 1.9 60'. Did anyone else find they ran slower at heathcote?
Mike.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
