Hey guys,
My gtt has around 250kw at the treads with an aftermarket turbo, pfc and all. It was tuned with Shell V Power 98.
I was wondering if i run V Power Racing 100 at the drags, would it help or hurt the power output? is the different fuel gonna mess up the tune, a/f ratio and etc? hence good or bad for engine/turbo?
Cheers guys
Edited by BaysideBlue
  • Replies 42
not a ad idea at all. it will not improve your performance at all but will make your safety margin slightly bigger. will also not mess up your AFR's.
I agree, you will improve your protection from pinging but you may actually lose a couple of killerwatts due to to fuel being less volitile....(burns slower so you need to add more timing to compensate) but i doubt that you would notice as it would be more to do with air temp/relative altitude than 2 RON difference in fuel.
Andrew
Stick with your usual fuel and octane booster. You won't gain 7 points on anything but base unleaded, maybe 2-3 tops on 98 octane.
I recently ran some nulon pro strength through mine on the dyno and it had no effect on the mixtures and increased the detonation threshold significantly (enough that i could add 5 degrees of timing before any audible pinging).
Adding toluene effects your mixtures as you have to add so much of the shit to get a significant increase in the RON of your fuel. Were talking 5-6 litres per tank of fuel (thats near enough to 10% by volume) to get a couple of point increase.
and if you stuff up things can go pretty wrong. i was asking my mechanic about toluene and he said it is better to stay away from it cause a small mistake can have large consequences.
Depending on how far you want to go, toluene is the best option. It only aided F1 back in the 80's to achieve the high horsepower figures they had and ran.
Problem with the octane boosters is the higher the initial ron of the fuel the lesser increase you see from adding it.
mad082 can you explain your mechanics reasoning for not using/advising toluene?
V-Power will actually LEAN OUT your mixture, not richen it up.
Not by a lot, but mine went from 12.0 to about 12.2 on the Optimax Extreme.
When I put it in my car, I normally leave the AFR and just add some timing.
But I don't use it often.
thanks guys for the replys.
so using 100 octane fuel on 98 tuned engine will lean out the mixture which would increase safety margin but need to adjust timing. how exactly do i do that?
and also, is it worthwhile doing (pay the extra cost for v power racing + adjusting timing) for the so said slight increase of safety margin, without any real performance increase over the quater mile?
rule of thumb is if you are asking how to tune your car then dont do it yourself. Get a tuner and a dyno
Edited by Bl4cK32
higher-octane fuel will lean out the mixtures, except as the the octane level is the fuel's rating of resistance to detonation it will probably be safer for the motor.
However, using a higher octane fuel without a tune may not see any gains because the burn rate will be reduced and the motor will not be running optimally. Best bet, just run 98octane what your car was tuned with.
If you really must, an amateur way of adjusting ignition timing to get the most out of a higher octane fuel is done by moving the CAS anti-clockwise slightly, test driving and repeat until you reach an acceptable knock level i.e. 20-30. Or read up on paulr33 PFC guide.
Edited by BAMR33
ok sounds like theres no point using v power racing without a tune or at least adjust timing then.
thanks i will try that.
if thats how your planning on doing it. Dont bother. Unless you got a timing light and your checking base timing as you go, its not worth it mate. Will probably cause more problems then its worth.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
