other catergory
car : lancer evo 3
engine : 4G63
turbo : garrett
power 403 kws
60 ft 1.611 (best 60ft 1.53)
et : 10.583
mph : 135.84
tyres M/T Radials
calder park
workshop : advanced jap auto
tuned : advanced jap auto
Edited by vr4sigma
  • 5 months later...
  • 1 month later...
Driver - NutR33
Car - R33 GTST
Engine - RB27DET
Turbo - GT37/88R
Power - 360rwkw
ET - 10.91
MPH - 131.04
60ft - 1.67
Tyres - M/T ET Drag 26/8.5/15
ET - 11.29
MPH - 131.93
60ft -
Tyres - M/T ET Street Radial 255/50/R16
Heathcote 12/02/2012
  • 1 month later...
  • 3 months later...
  • 2 months later...
  • 2 months later...
Took my r32 GTS-4 to calder for my first time drag racing.
Best time of 12.26 at 114mph, done on budget $60 17" tyres.
Pretty happy with that for now!
still on RB20? what power/turbo ya got? Thats what i want outta my GTS4!
I'll update the drag list soon, it's been too long!
  • 3 months later...
  • 1 year later...
Car - R34 GTT
Turbo - GT3076r (.82 rear housing)
Power - 320rwkw
mph - 124
60ft - 2.21
1/4 - 12.21
Tyres - Kuhmo ku19, 235/40/17 (40% tread)
Fuel - United P100
Motor - Standard RB25DET neo with pon cams
  • 4 months later...
  • 3 months later...
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
