heres a q... i ran 13.1 @ 105mph with 1.9sec 60 footers.. with 205kw..
assuming i can still drive.. what am i looking at with semi slicks and 320kw? is low 11s out of the q. Pump fuel, Coil overs. Full street trim.
Well its not going to be a soft rear end drag setup. Its going to be full street style, drive there race and drive home (factoring in nothing blows up/breaks)
It was pretty good with traction last time i raced it and good traction on the street when i made 300kw but it wasnt as responsive as i had liked.
i have more traction on the street than i did at heathcote
My mate with his XR8 didn't find it to bad, he said gotta hold the burnout for a couple of seconds to make it a bit quicker off the line though.
Me too. I'd hope for the open to public events though that they prep the track somewhat.
The staff there were laidback as shit though, which was awesome
calder last night, my first time ever drag racing
my first run got me
15.132 @ 93.91 MPH with a 2.4sec 60 ft
my best run got me
14.217 @ 93.49 MPH with a 1.915 sec 60ft
10psi/front mount/3inch from dump, Dr drift dyno says 136kw.
235 595ss running street psi (38psi) and 6kg bc in the rear set at the softest setting.
i have no clue if thats fast or slow for my car, but im happy, i was getting consistent 14.2** when i launched properly.
  • 3 weeks later...
  • 3 weeks later...
He ran 11.7sec with a 1.7foot launch doing 200mph.
wut? I think you mean 200kmh dude
How long since the original list on the first page has been updated?
Probably ages... you ever been down the 1/4? I'm itching to get out there again
Anyonw running in the 10's other than Leewah? Says he has 600RwKw+? :S If anyone is, would be interested in knowing set up's/tires and 60ft time...looking at slowy trying to crack a high 10 once everything is set up.
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
