I don't know much about clutches, but i'll reply anyway. You say you smell burning whenever you go hard? Well it could be your brakes, if you're braking heavily or alot when you're going hard. If your clutch is not working good, as far as i know it will slip alot, and that's how you can tell if you need a new one. Exidy clutches are supposed to be a good brand also.
That's all i know :D
Ryan
https://www.sau.com.au/forums/topic/1740-clutch-done/#findComment-33089
The clutch will slip in higher gears (lower too - but not as obviously i think) .. like you'll put your foot down and the car will rev and you wont gain speed... you'll notice it.
If you continue to let it slip for a long time, you can damage the flywheel, but thats about it (i think) eventually the car will be undrivable..
mine went not long ago and i have a 5 puck brass button clutch in there now - absolutly fantastic!
Christian
https://www.sau.com.au/forums/topic/1740-clutch-done/#findComment-33112
Christian
I think theres a chance that you flywheel can shatter too. I drove
my to the point where it just wouldn't move anymore, not that
I'd recommended such an action. :) Smelling your clutch through
the air vents is a definate sign.
https://www.sau.com.au/forums/topic/1740-clutch-done/#findComment-39517
full face organic just means that it is like the stock clutch plate, i.e full face and made from organic material. You should specify a higher pressure plate like 2400lbs or such and maybe even steel backing on the clutch plate. As for driving the car with a slipping clutch, I did it and was shocked when we pulled it out. The actual clutch/friction plate was fine and had heaps of meat left but the pressure plate and flywheel where toast. It is not a good idea to ride a button clutch. :(:P
https://www.sau.com.au/forums/topic/1740-clutch-done/#findComment-39749
Alot of people have said it's a good clutch. Mine's basically a
custom one. Everytihng is Exeidy Dakien Full Faced Organic
except for the compound used. Pressure plates a bit heavier
too. It's supposed to be slightly stronger. I think it's a bit too
strong now cause I think the next thing to go on my car is my diff,
bit harsh on the takeoff. So I think it would be perfect for the 33.
Just remmeber to bed it in properly or you will regret it later.
https://www.sau.com.au/forums/topic/1740-clutch-done/#findComment-39881
Here is my clutch story -
Had a std clutch in R33 which I killed in about 3000 kays.
Then put in a single plate nismo one which lasted about the same.
Then I had to replace the gearbox & fitted a twin plate OS Giken.
I had trouble at the drags with this one slipping at the top end, so
we fitted a triple plate OS Giken clutch.
Then I blew up the gearbox (a Trust 6 speed!) doing burnouts in 2nd gear.The clutch still looked okay at this stage but one of the plates was starting to go blue more than the others.
When I blew up the engine at the 4.6.&Rotary Nationals in Adelaide in Feb, we replaced the engine with a OS Giken 3 litre.
The crank in this engine has 8 bolt holes for the flywheel(not 6)
so I had to change the clutch again!! Now I have a Quad plate,
Chrome moly, 8 bolt OS Giken clutch. I'm sure this one will last.
Moral of the story - Get the right clutch for your application first up
PS. At Drag Combat in May I completely smashed the std rear driveshafts in 2 places and have since replaced them with HKS
shafts. When the gearbox came out for a checkover the clutches
in the transfer case were fried 'cause I backed off the startline using Fwd only.
I now have a fresh transfer case, a fresh gearbox, HKS shafts front & rear, & a hydraulic torque split controller so all 4 tyres
better look out now!
https://www.sau.com.au/forums/topic/1740-clutch-done/#findComment-40742
Originally posted by Zahos
Hey ex-static
If u dont mind me asking, where are you getting the clutch done, and approx how much $$ is it going to set you back?
Zahos
I got it done at Ice Performance in Cheltenham, its an excellent clutch, very light, and very grippy! I highly recomend it.
-ex
https://www.sau.com.au/forums/topic/1740-clutch-done/#findComment-41124
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
