i got sick of doing the same thing on ns.com years ago here are a few good calculator sites. It is a simple calculation.
http://faq.f650.com/FAQs/ShocksSpringRateF...te%20Calculator
http://www.iroczone.com/calcs/chassis.htm
this one will give you a Kg/mm result also
Metric and imperial result
I've tried calculating it using them but I'm not too sure what measurements they're suppose to be entered as. I assumed in inches (") and tested a few of the measurements in SKs' thread but can't manage to get the same rates as him so I'm not sure if I'm doing it right?
Edited by Scandrew
Remmember the above calcs are imperial, i have a spreadsheet i made in metric. here is the equation for those who would like to know how the calcs work so you can make your own.
11,250,000 - Torsional Modules For Steel (Constant)
CSPWD - Coil Spring Wire Diameter (How thick is the wire?)
8 - Constant
NOAC - Number Of Active Coils (Coils that are free to move. Not coils seated. It may be that 1/2 of the top and bottom coil is seated causing a spring with 8 coils to have the distance of 7 free.)
CMD - Coil Mean Diameter (The diameter from center to center of the coil. Measure the diameter of the coil from wire center to wire center. If you know the coil is .5 inches thick and the outside diameter of the coil spring is 3 inches, then the Coil Mean Diameter would be 2.5 inches)
(11,250,000 x (CSWD x 4))
(8 x NOAC x (CMD x 3))
All Measurements in inches - calculate as decimal ie 1/2 inch as 0.5
With your calculator and the following measurements I have an end result of 46037.96138.
Wire ID: 11mm (0.433in)
Coil ID: 64mm (2.522in)
Coils: 7
did you input inches or mm? it needs to be in inches.
using http://www.racingsuspensionproducts.com/spring%20rate.htm i get 14kg/mm or 794Lb/in
URAS, you wouldn't happen to be able to recommend spring specs for 4F 3.5R kg/mm rateswould you? :rolleyes:
i.e If I have a coilover currently using a 64mm spring ID, would I be able to use a 61mm spring ID on it?
Edited by Scandrew
    • A little follow up here on the ceramic coating.  We've had storms galore here and I've done a few ks, enough to gross them up  Consensus is that they didn't get as dirty as usual, the coating definitely repelled a little of the dirt and I think they kinda snowball. They get a little dirty and then they get dirty faster which makes sense. Cleaning them regularly would allow them to protect better.  Cleaning was a breeze. I tried first to just hose them off which, unsurprisingly, did nothing. But, making the wheels wet and then just wiping them over with a used but clean microfibre cloth was all that was required. I didn't need any cleaner at all, just water and a cloth. The wheels look amazing again.
    • Gave her a nice wash today and took extra time to clean off the tree sap and tar and crap. We have a usable garage now so she'll stay cleaner longer. Took a few snaps in some nice light afterwards.
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
