Hi Guys,
My current tyres, falken 451's, are bald on the inside camber. I have 18" impuls rims 235 front 265 rear. I've had a look on the net for tyres over the weekend, hankook ultimate, potenza S03, Toyo T1r's, falken 451's.... are there any others i should consider? what would people recommend?
Ideally i want something that will last longer than the 451's did for the inside camber wear although i plan to get a camber kit to help with that. My car does not see the track, road use only.
Also, can i just change the rear and leave the fronts as is? i'e have different brand/model tyres on the front compared to rear? I think i can get away with the fronts as is for a little bit.
Cheers
https://www.sau.com.au/forums/topic/174064-tyres/
Even if different tyre pattern? I just got a price for federal 595 235 front $190 265 rear $280. These are a different tyre pattern i assume.
Tempe tyres say they dont have and cant get my rears in falken 451, only falken 452. :rolleyes:
Edit: Actually im leaning towards getting the falken 452 now since the tred pattern is similiar to the 451 and from what i have read they are a decent tyre.
My only concern is here, http://forum.e46fanatics.com/showthread.php?t=407372 - they say the 452 is bigger than 451! Im not very knowledge, are they saying they are wider and taller or just wider? From what they are saying it sounds like i should maybe get 255 rear instead of 265 i currently have.
Can anyone please help with this? Im happy with getting the 452 now from what ive read so can anyone comment on that link?
Edited by Xizor
https://www.sau.com.au/forums/topic/174064-tyres/#findComment-3195969
Tempe tyres say they dont have and cant get my rears in falken 451, only falken 452. :(
It's ok to have different tread pattern from the front.
If you get the 452's, just get them in the same size. So you've got 265's on the back so get 265's by whatever profile you've got now (35 I Think for 18's). So you should be getting 265/35/R18
https://www.sau.com.au/forums/topic/174064-tyres/#findComment-3195998
Tempe tyres say they dont have and cant get my rears in falken 451, only falken 452. ;)
The 452 superceeded the 451, it should be a better tyre.
By bigger they'll be referring to tread width i'd say. I used to have 245 451s and the tread width was quite narrow, about 220-225mm. so they looked a bit skinny and didnt protect the rims well. From the links that Xizor posted some are bigger and some are smaller, just check the tread width column for the size you want.
https://www.sau.com.au/forums/topic/174064-tyres/#findComment-3196869
I like my advan ad07s to be honest.. so much grip.. but will cost you more than 400 a corner
but i also have t1rs.. excellent value for money..
both have been to the drags and track day.. no complaints...
t1rs have lasted me for ages..
bought them end of last year.. 05/12/06 to be exact.. still got over 6mm left..
love it..
https://www.sau.com.au/forums/topic/174064-tyres/#findComment-3196970
    • If that's the wiring from the factory, I'd be inspecting the loom everywhere.   Any signs of that anywhere else, and seriously, I'd get rid of the car ASAP before the electrical gremlins make it worthless, or it goes up in flames on its own. That is scary how that insulation is failing!
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
