I have a really n00b question.
If i drive 80% of the time off boost (<3000rpm), will lowering my boost help with fuel economy?
imo, i say no. but then again, i'm not actually sure.
Can anyone enlighten me on it?
Thanks!
Edited by dan.1337
https://www.sau.com.au/forums/topic/174123-will-lowering-my-boost-help/
I'm just thinking that when I'm off boost, it drives like a normal 2L engine (rb20) and when on boost, that's when the air + fuel etc come in.
Is that true? Or when I'm running below 3000rpm the turbo is still spinning and pushing air into my engine?
If anything, when I'm giving it stick it's between 4000-6000rpm but i'm not sure if I'm on full boost during that time as I'm too busy watching where I'm going and not my boost guage.
I was told that my dropping my boost pressure below 10psi, I'll get better fuel economy. Right now, i'm running 16pounds.
If it helps, here are my mods:
rb20det
HKS 2535
550cc injectors
Link ECU
Bosch 040
cooler, pod, 3" full exhaust.
i'm currently getting exactly 300km to the tank.
Edited by dan.1337
What? No. If your not boosting then the turbo is not pushing air into your motor. It depends how you treat the throttle whether you get good or bad economy.
Thats what I thought. If I'm not really pushing air into my motor (<0 on boost guage), then lowering my boost will not help. Almost all my shifts are below 3000rpm unless I need to overtake those new trams. Damn they're fast.
hmmmmmmmmm
you want better economy but you have a bigger fuel pump, bigger injectors and a after market computer, all of which help get more fuel through, then u ask if u wind the boost down will you get better economy even tho your not boosting. sorry to say but u don't buy a skyline to get fuel ecenomy of a excel
hey i get really good economy outta 700cc inj bout 400-500km and thats rb25 gt3040, q45afm etc.
its just a crap tune get it retuned. also what injectors are they cause if there rx7 ones then they uise heaps of fuel. Also turnin down the boost wont help if you drive off boost as its not like your driving on full boost all the time.
i'm not looking for the economy of a prius or excel. definitely didn't buy the car to save the world. just thought that 300km to a tank is a bit low, i'd even be happy with between 350-400 which isn't all that far away from what i'm getting now. just unsure why i can't sqeeze out that extra 50-100km esp when i'm driving off boost a lot of the time.
my injectors are Denso 550cc. direct drop in for the engine so i don't think they're from an rx7 (unless i'm wrong).
my car was tuned recently. it used to run extremely rich (almost on the verge of flooding the engine) and everything on the inside has been blacked out with carbon deposits. i was told by my tuner that over time the crap will be spat out of the system and economy should improve again. i don't think he's a crap tuner as one of my friends who has had his tuned by the same guy with almost the same mods gets 400 to the tank each time.
i might go thru a couple more tanks of petrol first and see if things get better. each time i drive little black spots of carbon which have been softened by the exhaust condensation is spat out (quite a lot of it) - so i know that something is heading in the right direction.
will be holding off on the ebc for a little while.
thanks for the all the insight tho!
Maybe get a new oxygen sensor, and if that doesn't help get the ecu retuned. Get the workshop to spend a decent amount of time on the lower load points etc to improve your economy.
i suspect the link doesnt do closed loop so an oxygen sensor wont do squat
you should confirm with your tuner if it supports closed loop 02 feedback or not
if it doesnt get it tuned for light cruise / low load or change ecu's
if it does, then get the 02 sensor checked/changed and or get the afrs for light cruise trimmed
also drive normally, dont back on/off throttle constantly to raise boost and make boost nosies
another idea is your get your gf or mum / dad to drive your car, see what economy they get in it - i bet its much better than what you get
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
