hey guys, just got some coilovers on the weeekend, JIC magic 12k/9k lol.. anyways ive got bbs rims 17x9 +22 offset all round. 255/40/17 tyres.
its set to 345mm from centre of hub to the guard and its scrubbing on bumps, whats the best ride height to raise it too? ive looked at the scrub marks and its just touching the outisde of the tyre, i think if it had 245's or 235 tyres it would clear it.
i dont really want to camber it as its a waste of tyre life (for my daily driving use), ive got the c-spanners also so shouldnt be that hard to raise it up.
cheeeers!
https://www.sau.com.au/forums/topic/174146-ride-height/
Ever thought just make adjustments until you dont scrub? just count how many turns/clicks you make and repeat all around
errr thats the whole point of this thread lol, im asking a exact measurement that is best for ride height & handling.. other guys here are just helping out giving some other opinions of what you can do to stop scrubbing
https://www.sau.com.au/forums/topic/174146-ride-height/#findComment-3197504
Well best ride height is 350 - 340 for best handling.. but it is rather low .. Im actually pretty sure its even lower on a R32.. If you PM sydney kid he will give you the exact measurement for best handling. It may not stop the scrubbing though
Lipping may cause cracking but you wont see it ..
Depends where the wheel/tyre sits have you thought of stretching over some narrower rubber?
Edited by DECIM8
https://www.sau.com.au/forums/topic/174146-ride-height/#findComment-3197754
if you dont want camber run either toe adjusable rods or camber rods.. you can also get camber heads for your coils
And its about $40 a side of lipping.. It will push the guard out about 1-3mm which is not noticable tho.. $50 a side max. Go somewhere good though.. A guard roller makes it alot nicer I think.
hope thats helped
https://www.sau.com.au/forums/topic/174146-ride-height/#findComment-3199750
c'mon mate half of that post is complete rubbish. you say if you don't want camber buy toe rods or camber rods? excuse me? what is a toe rod going to do (bearing mind pretty much every car on the planet has toe adjustment from factory, AND this is not his problem)? and how does a 'camber rod' not adjust camber? what's the point of it then? as for camber heads for your coils, never heard that one either but I assume you mean an adjustable upper mount for the coil-over. well that's about as usefull as a fart in the bath. you cannot adjust camber that way in any skyline.
hanyou. my advice is don't take any of this advice from decim8.
your problem is simple. your wheels are 1 inch wider than stock, and have 10mm less offset (so they are 10mm further out, plus the .5 inch). add to that the 255 tyres and the low ride high and you get interference. you need to either:
raise the car by 10mm or so
use narrower tyres (either 245 or 235 will be fine on your 9inch rim)
add some camber at the front (you need adjustable, or shorter upper control arms for this)
have the guards flared, or lipped or rolled (very risky at the front as GTRs have alloy guards which are very soft)
I would suggest you raise the car by 10mm. then down the track when your tyres wear out, replace them with 235s or 245s then you may be able to lower it back down if that's what you want.
https://www.sau.com.au/forums/topic/174146-ride-height/#findComment-3199953
Well I know you know alot more than I do .. So id take barrons advice..
However I didnt say NOT to use camber rods .. so im confused what your saying to me .. I said the reverse.. TO USE THEM??
I was refering to these
http://www.nengun.com/cusco/adjustable-rear-upper-arms
I am wrong with toe rods.. yes .. why I suggested them Im very confused obviously was not totally switched on. Which was wrong of me I apoligise.. And coil heads do adjust the camber -3 to +3 if its cusco from memory.. And as I stated as a last remark "you can also get camber heads for your coils" (i.e being a last effort) Im only passing on what ive learnt .. But like I said you know alot more so Id back what you say..
http://www.nengun.com/cusco/pillow-ball-upper-mounts
* Taken from sale pitch - Camber adjustment by sliding the plate and pillow ball sections
We both know what is said on here is not always true and what works for one will not work for the next in all situations. I learn most things from on here and apply them to my car when I can.. With this I have not tried any just researched them...
Obviously you are a person with alot of background in this and im just a guy who wants to help out a guy who has no idea what to do. In saying this I only tried to help and no one corrected me or questioned me until you, now ive learnt my mistake and amended it..
So I stand corrected..
Edited by DECIM8
https://www.sau.com.au/forums/topic/174146-ride-height/#findComment-3202308
yeah no worries. I guess I do come across like a bit of a wanker. i guess I am one. but to help out and clear some things up. so appoligies if I seem a little blunt. :)
the pillow ball upper mounts, or camber plates DO NOT WORK on a skyline. They are used on cars with what is none as macpherson strut type suspension (silvias, 180s, GTI-Rs and most other povo cars). Skylines have dual wishbone suspension meaning the length of the upper and lower arms is what controls the angle (camber) of the upright. in the other mentioned cars the shock itself is the upright so adjusting it's mounting adjusts camber (and castor). you can't do that in a skyline. you need adjustable upper arms.
you are almost on the right track with these, but they are only suitable for the rear of the car. he is having problems with the front end.
and to help further. camber rods is not a comonly used term. I think you are combining castor rods and the word camber. there is no such part as a camber rod. in skylines to adjust camber you need one of these:
adjustable upper control arm
adjustable lower control arm
adjustable offset bushes (for upper control arm)
any one of those three will do the trick. the most common is to change the length of the uppper control arm either with the offset bushes in a factory arm. or by using a replacement aftermarket arm that can be adjusted in length.
https://www.sau.com.au/forums/topic/174146-ride-height/#findComment-3202378
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
    • Duncan:- it affect both sides.  Driver side is worse.
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
