ok, one of our headlights only lights up when it feels like it, but if you beep the horn, usually it will come on?
what would cause that?
also, car has 150k with original coil packs, had iridium plugs that have caused no problem for 50k at 200 odd rwkw
car has just started randomly hesitating, usually at cruise, havent seen it do it at high rpm yet
time to start looking for replacement coilpacks? or could it be something else
nothing has changed on car in 20k
Edited by Spook's_Skyline
https://www.sau.com.au/forums/topic/174151-diagnose-this-x-2/
ok, update
car just completely died on me
went from small heistation to massive stutter to stalling immediatley
turn key on, engine revs just drop to stall immediately
let it sit for 1 minute and was able to limp car home
damn, first time shes ever let me down :yes:
i had the same problem with my headlight, mine wouldnt work, then when i slammed the door it would work..
it ended up dieing and not working at all so i went on a hunt to find out why and it wasnt getting any power so instead of stripping the loom really far back i did the dodgey and hooked it up to my parkers... seriously who drives around with only parkers on anyway haha :(
ok, bit more info about the hesitation/dying
cars been at shop for the last two days
of course when its in shop, behaves perfectly, no dramas at all
had diagnostic guy come out and check everything, no faults, coils look ok
mechanic seems to think that afm mite be faulty?
problem has only ever occurred at light load, not on boost
cruising at 110 on highway, and then cruising at 60km/h the other nite
im looking at changing my afm to a bosch z32 anyway, so mite give that a try
fuel pump is a reasonably new walbro, probably 12 months old
havent had any issues with it that i know of since install
i am watching the pfc hc whenever we drive anywhere now to see if something funny happens with the afm reading when this occurs
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
