hey guys, im gointg to attempt to make a rollcage for my drift pig!
i got no idea where to start. ive been sussing out designs etc..
i plan on stripping the interior and making it a weld on not a bolt on...
anyone know what thickness piping i should use... also miled or stainless etc?
fat chance but anyone got a write up?
cheers
https://www.sau.com.au/forums/topic/174160-roll-cage/
Also have a look in the gallery on that site i linked above, has some different designed cages to give you a few ideas.
Cams approved cage bent up for a series 6 RX7 cost about $900 for material and all bends and cuts, then you need to weld it all in ... it might be cheaper for other cars due to the rx7 being a complicated design. that was from a places in Mc Graths Hill NSW
https://www.sau.com.au/forums/topic/174160-roll-cage/#findComment-3198435
Craved i've discussed with Eddie (p.c.e) about rollcages in the last week and will probably be getting him to do a basic 4 or 6 point cams design sometime in the next <3mths. Actually he's doing 1 for a DR30 and 180SX right now at the shop.
Think he said the seamless costs him $26/m where as he can get a full length of exhaust tube for less then that.
Edited by benm
https://www.sau.com.au/forums/topic/174160-roll-cage/#findComment-3198724
i have payed $26 a meter for 2" 304 stainless pipe for exhausts.. so that seems pretty cheap. its the mandrel bending thats the really hard part, without spending alot of cash on a hydrolic/electric bender.
https://www.sau.com.au/forums/topic/174160-roll-cage/#findComment-3198738
if u wanna make it real awesome weld some bars that join up all the strut towere through front firewall etc. Maybe even rip out dash and weld a new support bar through the dash replacing the stock one. Goodluck and post some pics
https://www.sau.com.au/forums/topic/174160-roll-cage/#findComment-3198829
No point doing it if it isn't going to be done properly, likely to just inflict more harm on yourself.
I dont think you could stress that pioint enough if you tried :)
A poorly made/designed cage is MORE dangerous than not having one at all.
IMO - Your better off paying someone who knows what they are doing.
For ~ $700-800 you can have a 4-point fitted in mild steel to a skyline. Which, for your own personal safety, is absolutely nothing.
You might save a few hundred with DIY, but if its not correct, your more likely to die or permanently maim yourself in the event of an accident than if you had no cage at all.
https://www.sau.com.au/forums/topic/174160-roll-cage/#findComment-3205363
ben the one you posted won't pass, it needs at least 1 diagonal, normally between the b pillars although I've also seen a-b and b-c on opposite diagonals. You don't need the horizontal bar between the b pillars for the rules but it is a good addition
we are doing this atm, the main problem is mandrel bending the main hoop (b pillar) you can't use a normal pipe bender it will crush it too much losing the strength.
The other main trick for CAMS is you are only allowed to have 1 bend on the front legs so you need to go through the dash, you can't bend around it.
And if you don't think strength at the A pillar/roof is important think again
https://www.sau.com.au/forums/topic/174160-roll-cage/#findComment-3205572
That wasn't the 'exact' design im going to get but it was the closest I could find on google in 3mins at the time.
My exhaust mechanic does the cages, he has a normal pipe bender but for those b-pillar bends he uses a mechanics machine up the road from him, the rest he can do on his pipe bender. Not sure on costs yet because I haven't even got my panel damage repaired yet (even though I have half of it in primer :P)
https://www.sau.com.au/forums/topic/174160-roll-cage/#findComment-3205623
;) Having my non abs s.wheel go through my skull, as well as worrying bout a tube from a snapped home weld isnt on the cards.
*thinks* wheres that home made helmet thread :P
https://www.sau.com.au/forums/topic/174160-roll-cage/#findComment-3215752
Heress a link that will no doubt assist in this roll cage
http://www.metalgeek.com/cgi-system/php5.c...tatic/cope.pcgi
it will determine the cut required to closely join tubing in order to have a neat joint and allow good welding.
https://www.sau.com.au/forums/topic/174160-roll-cage/#findComment-3220554
  • 4 weeks later...
hey guys! my old man, at seven hills has all the tubing u will require to bend/build ur cage.
call him on: Rod Andrews - 9838 0032
and say that i put you onto him for some chrome moly or mild steel for a cage!
he has a bender there too, and we have done 1000's of cages since the shop opened in 1989.
so talk to him if you have any queries, make templets out of cardboard to suit ur roof profile and "b" pillar for your main hoop! and start workign form there. and if you want it cams or andra approved or any other racing approval, check with the governing body before attempting to BODGY one up!
Garth
https://www.sau.com.au/forums/topic/174160-roll-cage/#findComment-3263214
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
