I am regrettfully putting up for sale my Drift Machine, due to work commitments and location it is impossible for me to Slide atm.
So instead of the car sitting in a garage it should be out on track smokin.
The Drift/Track Skyline comes with a car trailer which has tyre racks and long alloy ramps to make transporting the car effortless.
The car has done 2 rnds SD, 1 rnd QR and 10 practice days and been well looked after.
CAR
Nissan Skyline R32 4dr
7pt Safety 21 GTR roll cage
Racing Logic coilovers 12K front 9K rear
R33 Calipers & Rotors
Adj Suspension Arms Front & Back
Extra Lock Steering/Tie Rod ends
Locked Diff
Whiteline Front Swaybar, GTR Rear
GTR bonnet
Rolled guards Front & Rear
BN Front Bar, Uras Sides, Rear pods
D1 Carbon Fibre Wing
Border Carbon Fibre fixed back Race Seat
Sabre Racing harness
GTR intercooler
Remote Oil Filter/Cooler
Strut Braces Front & Rear
3.5" Custom S/S Exhaust
17x9.5 Koya Drif Teks GTR Offset x 2 SETS all with brand new tyres.
Alloy wheel nuts-Blue
40mm Alloy Radiator with Twin Thermos
3.5" one-piece tailshaft
Bosch 044 Fuel Pump
2L Alloy Surge Tank with AN fittings
R33 Gearbox
NPC 2800pd 5puk Clutch
NPC Billet Flywheel
Momo Steering Wheel
Microtech LT8 & Dash Mount
Blitz Boost guage
Autometer Oil Pressure guage
ENGINE
RB26/30 Engine with Cometic Head Gasket-(Fresh Build)
GTR cams
Polished Intake Plenum
570cc Injectors & Custom Billet Fuel Rail
SARD Fuel Pressure Reg with Guage
Stainless Split Pulse Exhaust Manifold Top Mount
GT35/40 Turbo .86 rear
46mm w/gate 14.7psi dumped atmo
ACL Race Bearings
Hastings Moly Rings
7L Baffled Sump
Alloy Breather/Oil Separater Tank
4" Intake/Filter
400rwhp or 300rwkw @ 14.7psi or 1bar
** SOLD **
PM for any more details/pics etc
Edited by pssiii
https://www.sau.com.au/forums/topic/174163-r32-skyline-4dr-drifttrack/
Cheers msport180
I think your R34 4dr looks tuff as, nice colour.
Yeh, all the hard work's done....!
thanks!!!
yeah its the orange that does for me, like a moth to a flame :laughing-smiley-014:
Still looking very nice, my mate bought your ute which is the one in that pic towing I'm guessing? Just curious, was this your car or PSI's?
Yes, thats the ute that I did the 2jzgte Auto conversion on, fantastic tow car.
The car was a non compliable shell we had at PSI, I built the car and all parts used on the car were supplied by myself, I was a partner at PSI and ran the workshop inc building drift cars and conversions even painting.
Cheers
PPL this car has it all (mods, knowledge when put together, and tuning) this machine is more reliable than my daily drive. I know of more than 190hr spent on this car.
The mechanic who worked on this car is a true professional and perfectionist. He had a datto 1600 sedan with a CA18 that beat my mates RB25 sprinter (mind u it ran 11 secs quaters every day of the week) reliably every day of the week.
This car is a true work of art Good luck with the sale.
The person who buy's this machine will be satisfied 1000% through and through.
Peace out.
Edited by DRF72
Thanks Luke,
You make it sound like I know what I'm doing...!
There has been more like 500hrs+ building this car...!
It is still a fresh build with plenty of life left in it...!
Will definately suit someone wanting to drift at high level or track sprints.
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that green thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
