what so good about them???
As mentioned it's replacing the S03 & supposedly was tested at Mallalla against the S03 & had better lap times.
Bridgestone seem to be very confident with it's performance as they've spent $$$$ on marketing.
I was quite impressed with the Adrenalins & will definitely be getting a set once I go through my T1-Rs.
https://www.sau.com.au/forums/topic/174165-re-001/#findComment-3197140
I had G3's on my old VR V8 cop car.
ok tyres, but really, for the cash, they were crap.... crap i say. wife lost it a cple of times. just didnt have the grip youd expect them to have, on a slippery surface.
best priced and performing tyres Ive ever used on a car are my current fare; Hankook Ventus K104 awesome tyre, $190 ea for 17x 235
I dont see how you can lose traction with these tyres on the street - if you do then you're doing something wrong. ie coming too hot into a corner, or perhaps braking thru the corner (big no-no; always end your braking B4 you hook into the crnr)
mind you, i do have AWD and a few extra hundred kgs in the stagea so maybe that makes a difference to a RWD skyline, in the way that they handle..... but this set should last 4yrs (35,000kms). top value. id argue that with anyone.
best bike tyres Ive had were Michelin Pilot's, top of the range goodness :) $290 for rear and $230 for front. worst tyre was Michelin sports, long range tyre not made for kneedown cornering. meant to last 12000kms, I ripped mine up in 5000 lol.
https://www.sau.com.au/forums/topic/174165-re-001/#findComment-3197994
michelins hot spot is in the high temperatures tho isnt it, whereas bridgestone is better known as an all rounder and wet control tyre.
Id take pirellis over both tho. but I am going to go with these andrenalines ive decided.
https://www.sau.com.au/forums/topic/174165-re-001/#findComment-3198119
I had GIIIs on the R34 and they were absolutely brilliant. Only problem was when I went to replace them the rear 255s were going to cost $450 each!
Went for Michelin Pilots and they have been awesome, but as usual I only got just over 10,000km from them.
Might try these out next.
https://www.sau.com.au/forums/topic/174165-re-001/#findComment-3198187
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
