Nissan Skyline R32
December 92 model!
Manual silver coupe Turbo
Original 150,000kms
Mods:
• Hypergear TR43 turbo, brand new! Paid $1800 for supply and fitment
• Braided oil lines
• Power Spirit front mount intercooler
• Polished piping
• KYB non-adjustable lowered coilovers (nice and stiff)
• New clutch
• New engine (only 40,000 kms on it)
• Turbotech boost controller
• Bosch 040 fuel pump
• Jasma 3” turbo back exhaust
• Stainless induction pipe
• HKS SSQ BOV
• Boost gauge
• White face dash
• Alarm/emobiliser
• 3A racing pod filter
• Denso spark plugs
• GTR side skirts
• GTR rear wing (not on the car)
• Type M front bar
• Nolothane castor bushes
• Nolothane upper arm bushes
• Pioneer CD player
• Pioneer 6X9 back
• Pioneer 6” front
• Standard 16” wheels painted black, good tyres
• LSD very smooth for daily driving
• Car is serviced every few thousand kms. Has new fully synthetic oil, oil filter, fuel filter, air filter, coolant, AFM
Has probably more stuff I have forgotten. Car drives very smoothly, interior is clean, paint is good, will not disappoint. Body is in pretty good condition has one minor dent in rear quarter but easily fixed but not too noticeable. Mechanical inspection welcome. Reason for sale: uni student and no income. May trade plus cash adjustment my way. Car does need a remap as bigger turbo is causing pulsing through AFM causing it to stall occasionally. Should make 200+ rwkw quite easily with some tuning.
Price: $12,500 negotiable as is or $13,000 neg when it gets remapped by Jeff from Speedlab
call Dan on 0401 936 982 if interested. Throw me your offers but nothing stupid as I'm not desperate to sell.
https://www.sau.com.au/forums/topic/174174-r32-skyline-coupe-manual-turbo-sa/
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
