I know the roll cage is probably the the single most expensive purchase to go racing, but after that it's all down hill....
Once the cage is in and you have the other safety items installed, you can go racing. To grater belief you don't need to have the car as fast as she can be or have new race rubber or the latest "go fast bits" ect..ect.. JUST GO RACING. Half the thrill is actually being out there and giving it a go. Learn the craft, become a better driver, have a s%#t load of fun and then... When time and budget permits, take the next step.
Life is too short! I have stuff all money to go racing, so does Briggsie, Perry, Maxfeild..... The list goes on. You simply don't need a V8 SUPERCAR budget to live the dream.
JUST DO IT! While you're still living and breathing.....
If only it was that simple though...
  • Replies 42
Posted Images
  • 3 weeks later...
I hope to run my Gtst next year. it's only got a new front mount, greddy plenum, power fc, 3inch exhaust and a roll cage. should there be anything else i should put in?
You will need an approved harness, window net, extinguisher, battery isolator with remote pull wire so it can be operated from outside the car,
race suit, plus your car will need to log booked with cams, plus a few other things CAMS website has a detailed list of requirements for circuit racing. For a good look in you could have a go at regularity, usually run by the MGCC at Symmons and the requirements are only same as running a club day I believe.
(Rocket_Rosco @ 3 Jul 2007, 06:37 PM)]
amen to that :sorcerer:
Well that means im only $14995 short :D
thats cheap, its cost me more than that for a dirty old pos hq, i wish i hadnt started hq, i would be in a skyline :rofl:
do you need a window net for TSS? I notice that not all of the cars had window nets last round.
Yeah you do a window net (only Historic Touring Cars are exempt, Targa class used to be but no longer), they cost a bit over 100 with quick release brackets if too lazy to make some up!
My cage for the RX7 will look like this. Allow $3500 + about $200 per bar extra. And thats the reduced price if you provide the car stripped and without glass fitted. Painting and padding is also extra.
Wheres the best place to get the net from stu?
Im not sure if any of you remember Leo's R33 GTR V-spec from up north, but the guy that built that is doing my cage. Stu, He's currenty putting the finishing touch's to his series 6 RX7 too.
Yeah I spoke to Spurry about mine, still debating if I want to drag it up and back on a trailer though!
    • I bought one for a 32 and it was junk, found its way into the bin
    • have a look at the other 2 stock rubber strips marked in blue. As you can see, they press against the cooling panel and leave marks. If the cooling unit panel isn’t there, the strip press against nothing therefore have no use. So Nissan was thinking ahead when they manufactured the cars, as they must’ve known people will install the panels in the future. Otherwise think about it, why else would they be there? Therefore that in itself directly infers that cooling panels do something. It might be to stop water and stop some air from going above the cooling panel so more of the air can be redirected between the cooling panel and the front bar. I tried to take a pic of it while the bonnet was closed but u can’t see shit in the photo
    • @DraftySquash @Duncan i misspoke, or this might be the other way. someone sent me a low res pic of it on It might completely close off the gap in red like in the second pic (second pic has gktech cooling panel on) .The 3 holes are for the plastic rivets used to secure down the front bar. The outer holes on the radiator side go underneath the condenser brackets If thats the case then there’s going to be no air going in through the grill between the bonnet and the bar for the radiator and condenser. Isn’t that bad? I mean less airflow to the radiator and condenser is all I’m saying
    • Interesting. Some of them were tight to lol
    • That's right, simple but works. Run out of load? Rescale the table lol. Want to be lazy and not rescale? Drag the K
