As stated in the title, i am currently tracking down a GTR Bonnet for my R32 Gts-t.
From what i know, all the needs to be done is that the latches need to be brought forward a little.
Is this correct ??
Has anybody performed this conversion on their car before and can offer some advice ??
Thanks for the replies.
Booster, i have actually purchased a GTR grille so i will be using that.
And, no, i'm not doing it for a weight saving, i'm actually doing it for the look.
It looks so much better, especially when you have an aftermarket front bar like mine.
Is it lighter? Its made of aluminium it's ALOT lighter. Only way youd get lighter than ally is if you made it out of carbon.
Most people get it for the look though. Im lucky, mine came with the full gtr kit from Japan, not sure id make the effort to get it if it hadnt.
Red17
Buz-iit,
No-one reproduces them and they are so difficult to get.
Mine took a lot of negotiation and a lot of cash to get. Plus, i had to pay to get it painted.
Wouldn't go through the process again as it took $300 just to get the grille and have it sprayed.
The car looked fine without them but i'm sure it would look so much better with them though although it is a $1000 transition.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
