I need some help and advise on this one please.
Idle moode:
My car seems to drop in idle when the Engine is hot.The idle drops right down and back up again past 1500rpm and drops again. This keeps repeating and eventually the engine stalls.
When driving:
I loose power some times in 1 st gear or second and suddenly it hits power and everything seems to be normal.
I have changed my coil packs but I have had no luck.
Does an yone have any suggestions to help me out????????????? Please
I have not checked the oxy censor or air flow meter for faults?????? any suggestions on how to test whether these are faulty?????????????? please help
https://www.sau.com.au/forums/topic/174221-r32gtr-help/
Idle moode:
When driving:
https://www.sau.com.au/forums/topic/174221-r32gtr-help/#findComment-3197602
check for a crack or hole in your intercooler piping. i had the same problem in my 33 gtst and a friend had it in his 33 gtr, we both got coilpacks but nothing happened. then i found that the hot pipe from the turbo on mine had a huge cut in it where it goes through the body, my friends gtr though, his hot pipes to the i/c were all cracked and perished.
hope this helps,
cheers
Linton
https://www.sau.com.au/forums/topic/174221-r32gtr-help/#findComment-3197661
hope this helps,
cheers
Linton
Thanks i will have look
Cheers
:D
Dinesh
https://www.sau.com.au/forums/topic/174221-r32gtr-help/#findComment-3199519
sounds like AFMs
They need more than a clean. Open them up and you might find that the soldered joints have become unattached and will lose contact when you go over bumps in the road. This is why they work sometimes and other times, they run like crap.
Have a look in the tutorial section on how to do this if youre not sure
https://www.sau.com.au/forums/topic/174221-r32gtr-help/#findComment-3206270
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
