I need some help and advise on this one please.
Idle moode:
My car seems to drop in idle when the Engine is hot.The idle drops right down and back up again past 1500rpm and drops again. This keeps repeating and eventually the engine stalls.
When driving:
I loose power some times in 1 st gear or second and suddenly it hits power and everything seems to be normal.
I have changed my coil packs but I have had no luck.
Does an yone have any suggestions to help me out????????????? Please
I have not checked the oxy censor or air flow meter for faults?????? any suggestions on how to test whether these are faulty?????????????? please help
https://www.sau.com.au/forums/topic/174221-r32gtr-help/
Idle moode:
When driving:
https://www.sau.com.au/forums/topic/174221-r32gtr-help/#findComment-3197602
check for a crack or hole in your intercooler piping. i had the same problem in my 33 gtst and a friend had it in his 33 gtr, we both got coilpacks but nothing happened. then i found that the hot pipe from the turbo on mine had a huge cut in it where it goes through the body, my friends gtr though, his hot pipes to the i/c were all cracked and perished.
hope this helps,
cheers
Linton
https://www.sau.com.au/forums/topic/174221-r32gtr-help/#findComment-3197661
hope this helps,
cheers
Linton
Thanks i will have look
Cheers
:D
Dinesh
https://www.sau.com.au/forums/topic/174221-r32gtr-help/#findComment-3199519
sounds like AFMs
They need more than a clean. Open them up and you might find that the soldered joints have become unattached and will lose contact when you go over bumps in the road. This is why they work sometimes and other times, they run like crap.
Have a look in the tutorial section on how to do this if youre not sure
https://www.sau.com.au/forums/topic/174221-r32gtr-help/#findComment-3206270
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
