built from a shell up all sound deadning removed interior/engine bay painted (outside matte black)
REGO has ran out but WILL renew for anyone wanting to buy!
93 180sx
SR20det red top (new motul oil)
5 speed manual (new motul oil)
garret t28bb turbs
NEW braided lines (thanks tarek from racespec)
NEW ss manifold n all new gaskets
NEW ss intake
NEW ss dump
NEW K&N filter
NEW hybrid copy intercooler kit
s14 radiator
apexi front pipe
apexi cat back (hi flo cat)
NEW tomei rocker stoppers
NEW cometic 1.2mm headgasket
NEW bosch 040 pump
Blitz DSBC elec boost controller
speed lab remap 180rwkw @ a very safe 14psi (made this on a 38 degree day after 6 runs)
5 stud conversion with all new feroda pads
NEW rear discs /machined fronts
R32 gtst 4 pot calipers front
NEW poly steering rack bush's
NEW alloy steering spacer
NEW alloy cradle bush's
NEW nismo engine and gearbox mounts
vertex style front bar
vertex style side skirts
vertex style rear bar
f/g wide vented front gaurds
flared n rolled rear (with the typical dented in rears)
type x lights
type x wing
JIC FLT-A2 coil overs 2 way height/damper adj F8 R6
NEW D-max adj castor rods
NEW D-max adj rear camber arms
NEW D-max adj rear traction rods
NEW D-max castor brace
Cusco Front and Rear strut braces
Tein tie rods
Nismo GT pro mechanical 2way (with new nismo oil)
can come with interior if wanted or stay stripped with fixed back recaro
32 stock wheels (and pair of z32 as spares)
PRICE DROP NOW $12,800o.n.o!!
http://www.nissansilvia.com/forums/index.p...st&id=78603
https://www.sau.com.au/forums/topic/174224-fs-93-sr-180-many-mods-sa/
  • 1 month later...
