Rb20 Not Sure Anymore
Run it in open loop for now, and drop the frequency down. This lowers the resolution and requires more duty cycle to do anything, however good to troubleshoot. -
According to Josh, one of our local Americans, it seems the USA still can't get turbo systems quite right at a lot of places, so possible that they're not running great at all, but they've just not complained as NFI about getting it right...
Thanks for the info breakdown there. I put some body filler today for the first time, surprisingly it went decently smooth lol. I got the ratio correct both times when I did it, and the dent I had is at least 90% better. I put a guide coat and saw lots of black residue left so I'm putting another batch of putty which I'll need to sand off. A few dents I fixed up and checked with the guide coat and they were perfect, no black residue left over. Making progress! Only thing was after I fixed one spot, I put the epoxy primer to prevent rust. Though, I ran out of time for this other dent that I put filler for, I just put filler instead of the primer first. Raining tomorrow, hopefully the rust doesn't start to set it lol.
It might have the right plug but not be real OBD, they used J-OBD and all sorts of other weird things over time. Just checking...they ignition was ON when you tried this, right?
