Hey,
In the pic below is Sl33k 33 and his white tail lights.
I have got onto the person that made that set of lights. I havent seen the lights in person or the quality etc but i have spoken to him and he would make some more. is anyone else interested?
He said they would roughly cost $220 plus frieght.
If anyone else is pm me and ill give u his email.
Cheers
Adam
https://www.sau.com.au/forums/topic/174234-any-body-want-a-set-of-these/
  • Replies 61
Posted Images
YER mate cheers for the info.. have u seen these lights in person??
Any good?
was in briffa the other day have more pics of the car on the wall. Not in person but i do believe they will be very well made looking at there other work.
are they or would they be legal??
legal yer i guess cos u use red bulbs in them so it still comes on red.
group buy... hmm guess we could.. ok lets see if theres any interest if there is ill speak to him bout it
those lights look sweet and bam get lost the drop tank looks f**king awesome you're just saying that because you read a copy of wheels and saw that a torana had it and now you are just hating cos it's on a skyline you can't tell me that drop tank doesn't look hot
haha yer i got a drop tank on my torana hot hot!
Hey,
Cheers
Adam
You got anymore pics of this car.it looks tough!!
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
