okay, well while working on my other car the other day, i parked my skyline outside in the rain, and the indicator under the two red lights filled with water,
luckily nothing shorted out or anything like that but i decided to take the tail lights out and have a squizzy at them (aswell as empty the water :(
10 mins later the tail lights were in the oven softening up the glue and soon after they were apart,
basically i think i can make my tail lights look very similar if not identical to the ones as pictured,
in the picture you can see the red lenses have been removed from the lights, i did that and underneath is clear lights, now if i get sum thing like even vht nightshade spray and spray the inside of the lights under neath it would look very similar to the ones pictured
a bit hard to explain but will report back and post pics in the next day or so :D
sam
  • Replies 61
Posted Images
luckily nothing shorted out or anything like that but i decided to take the tail lights out and have a squizzy at them (aswell as empty the water :w00t:
a bit hard to explain but will report back and post pics in the next day or so :woot:
sam
Sam take a picture! also what temp you have the oven on to cook your lights?
sam
cant wait to see!
i will take some pics when i get home :woot:
um i think i put the oven on 200 :w00t:
they were in there for no more than 4-5 mins after the oven had time to heat up
will get back to everyone soon ;)
sam
80 100 ish mark
it takes about 8 minutes to heat up
ALL you're trying to do is warm up the particles in the glue, this will make it go back to being tacky and maluable thus allowing the parts to become seperate
200 degrees is just stupid, you don't use a shotgun to change the TV chanel, same as you don't use 200degrees of heat to warm up sealant glue!
i dont use an air rifle to change the tv channel wither... i use a remote...
all im saying is that 200 ambient heat for 5 minutes worked for me... but my lights dont fit in my oven with it being shut... forgot that...
so... what kind of gun do you change the channel with? :)
well yous can use 80, thats fine, i used 200 and nothing melted, came apart nicely :rofl:
still havnt finished, im using some black sealant because when you put the light cover back on there a gap were the red lense used to be between the cover and the other section of the light,
i will have to take some pictures tomorrow morning :worship: all the pics i take the flash on my camera totally f**ks it up cos its dodgy
ill write up a proper diy thingy later aswell :rofl:
so far im happy with the results :)
