Hey folks, i need some opinions on concerning FMIC's.
My friend owns a Gts-t R32, and is in the market for a FMIC
we did some research into the Blitz LM series intercooler(600x300x76), and read some good reviews, and was going to buy it....
but we recently visited 'Fussys Motorsports' in Sydney to ask if this cooler was any good, and Tan the owner of the joint told us that it was cr*p!!..
he told us that it wasnt as good as the ones he has(australian made ones same size but thicker core)..
so now we're kinda lost, !dont know which FMIC to buy?!?!?
what do you guys recommend to get??
australian ones or japanese delivered??blitz, hks, trust,etc..
Blitz LM Intercooler kit $1800 fitted
Fussys intercoller kit $1800 fitted as well..
open opinionz plz!! thaNks.. :D
https://www.sau.com.au/forums/topic/17427-which-fmic-to-buy/
bahaha of course hes going to say that... he wants u to spend ur money on his inferior one :D
dude... companies like HKS and BLITZ and TRUST spend megga bucks developing and researching these things... i would go for something like what they have to offer rather than some guy whos hacked a truck intercooler to bits and slapped together some end tanks... yeah they might still be good but whos to say theyre better? can he prove it? has he done major testing to show how uch better his are? i doubt it
even something like a GTR cooler which has pretty much the same dimensions u mentioned if u can get ur hands on one will do the trick quite well.
https://www.sau.com.au/forums/topic/17427-which-fmic-to-buy/#findComment-360870
That's what i was gonna say.:D
For sure anything japanese will have a better/higher overall quality then anything you can buy locally made.
Thats why my HKS type-s i/c is arriving in a few weeks:p
https://www.sau.com.au/forums/topic/17427-which-fmic-to-buy/#findComment-361556
I paid $1595 for my 600x300x70 'cooler made by Mick's Metalcraft. They've done many of the Horsepower Heros cars at Summernats.
Ive been impressed with it so far (i havent wound any boost yet).
Install it yourself - you learn a tonne about ya car while doing it.
Unique Autosports sell them.... www.nismo.com.au
https://www.sau.com.au/forums/topic/17427-which-fmic-to-buy/#findComment-362100
definately agree with doing ur own install and learning from it... i love pulling my car to bits and doing stuff myself even tho i really dont have any clue what im doing :(
btw i was meant to post a link in my second post to a guy selling a GTR cooler for 750ono :D would have made more sense that way.
plus i mean... its desinged for a GTR so its made by nissan... it must be good ;)
https://www.sau.com.au/forums/topic/17427-which-fmic-to-buy/#findComment-362478
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
