Well, the time has come to finally pick up my 2000 Series 2 Stagea tomorrow (Weds 27th). I will be flying into Melb (from Adel) in the morning and finding my way to Bayswater (apparently approx an hour from the Melb airport! That's one heck of a cab fare :( - anyone want to make some cab money? :D ) Then if everything goes well with the exchange, I will start my drive back to Adel asap. Just thought I'd share what this car is to me.
It'll be my first
- Import vehicle
- Wagon
- Six cylinder vehicle
- AWD vehicle
- Turbocharged vehicle (woot!)
I've owned. Needless to say I'm quite the excited little boy.
https://www.sau.com.au/forums/topic/174285-plenty-of-firsts/
Well, the time has come to finally pick up my 2000 Series 2 Stagea tomorrow (Weds 27th). I will be flying into Melb (from Adel) in the morning and finding my way to Bayswater (apparently approx an hour from the Melb airport! That's one heck of a cab fare :) - anyone want to make some cab money? :blush: ) Then if everything goes well with the exchange, I will start my drive back to Adel asap. Just thought I'd share what this car is to me.
It'll be my first
- Import vehicle
- Wagon
- AWD vehicle
Looks schmick Nick, pack the camera, enjoy the ride & avoid the boys in blue.
Cheers GW
If you do it in an hour from the airport you'll be lucky! I'd offer to give you a lift, but am out of Melbourne at the moment. It will probably be $100+ for the cab fare..
What is the address in bayswater? You might be better (ie much cheaper) catching the bus from the airport to town, then they train out to bayswater (if it is anywhere near the station). It won't be too much slower, and will be a lot lot cheaper!!
Thanks guys for the kind words.
It's on Scoresby Rd, Bayswater. Apparently I might be able to catch a bus from the airport to Box Hill then cab it from there. Otherwise the cab fare will cost me nearly double my airfare! Now that'd suck!
It's got a Dayz front bar but i think that's about it, the rest I think is pretty much stock.
I'll most definitely be keeping within the speed limits, I've heard about the boys in blue from Vic!
Appreciate the offer, thanks.
It's actually quite close to the train station so I might be able to train it there if I catch a bus to the city. Thanks for the info :)
yep - do the airport express bus to "southern cross" railway station (ie spencer st), then catch a train to the right station. You might even be able to get an express train! The bus costs about $15 and the train ticket will be something like $6 - much better than a cab charge!
Yeah sounds good, thanks mate!
if i was free, id take ya. but im at work. its like 5 mins from my house.
and its not that far from the station, maybe 10mins.
but the weather is shit today so i wouldnt walk.
if you get the train, get on the BELGRAVE line, and get off at bayswater.
how was your experience with them?
i wont say on a public forum coz im not allowed to
but looks like youve picked up a winner.
nice.
Everytime i go to Melbourne it rains on my ass... :laughing-smiley-014:
Caught a bus shuttle from airport to the city and train to Bayswater with no problems, took 1 1/2 hrs and $21 all up!
I must say, I love driving again. It's an incredible car to say the least, unbelievable amount of control and traction in the wet. I spent most of the trip back hovering around 120km/h with the occasional squirt and LOVED it!! It was like there wasn't any rain at all.
Unfortunately, after about 30mins driving, the 4WD light on the dash started flashing (the one under the fuel gauge) so I pulled over and checked the Attessa fluid reservoir (it's the one to the right panel when you open the boot right?) which was low so I got some Castrol Transmax Z from the local Repco of whatever town I was in, and topped it up. Seemed allright when I restarted the car but light came on again after about 5-10mins. Discovered everytime I turn the engine off, it's allright for about that time, then comes back on. At about the same time I noticed a SLIGHT juddering whenever I stayed at a constant speed between 60-90km/h. Anything above that it was fine. If i give it a bit of pedal it goes away, it's only when I start coasting and stay between those speeds.
Would the fact that the dealer chucked on 17's on the car instead of the standard 16's caused the attessa system to chuck a wobbly? Would a tyre allignment and balance help?
The juddering is not there when the 4WD light isn't flashing, so it must be connected right? Any help would be appreciated!
JVP - Thanks for the offer too mate, appreciated!
The first thing you need to do is make 100% sure all the tyres are the same profile. Different rolling diameters will cause an upset with the 4WD system but it has a built in allowance for about 5-10% difference I think.
Next - how low was the fluid? There is a requirement to bleed any air out of the system if there is the slightest chance of any getting in there.
There are 2 bleed points too - one at the pump above the diff and one at the transfer case at the back near the top.
Whilst you are under there it would be a good thing to check out the condition of the driveshafts to the diffs and wheels. The wheel shafts are just like any other CV, but the front driveshaft should have almost NO play in it, unlike the rear that will (unless you have an LSD)
I hope some of this helps
The Stink
The Stink
Ahh ok, I've just had a look, fronts are Bridgestone B500si 215/55/R17 and rears are same but 50 series. I need to change to the same? Would swaping the fronts and rears do anything? Shame, cause tyres still have decent thread in them!
What are chances I've done some damage driving it 750kms with different profiles? arghh!
Edited by webng
Well, its my understanding that you would have put some extra wear on the clutch packs of the transfer case but that would be about it (anyone - feel free to shoot me down in flames here) as the attessa system would have attempted to correct the fact that the rears were doing higher revs than the fronts due to smaller circumference. Swapping them over will cause exactly the same problem so that won't help you out any.
The clutch packs are likely to have a bit of chatter on them now, but a complete fluid change and the correct size tyres should see things right hopefully. You will only need to change 2 tyres if oney is a bit tight, as it usually is when getting a new toy :(
You may even get a trade in on the old ones if they are still OK.
Probably didn't help that the fronts (55 series) were 38psi and rears (50 series) were 28psi too... :( When the dealer replaced the 16's with 17's in their workshop, silly me assumed they would check tyre pressure.
Considering it seems to fix itself everytime i restart the engine, I'm hoping it hasn't stuffed the Attessa system up. I'll be getting new tyres this weekend I think. Hmm... should I keep the 50's or 55's... decisions!
Oh yeah, it is a Dayz edition, got the badge at the rear, but apart from the front bar, I don't know what else it has that's different.
sa-sau cruise on sunday, Burnside Town Hall (greenhill / portrush rds) at 12.30pm......
might see you there :(
no, the attessa wont be damaged as yet, but just letting you know to be aware, thats all.
Will definitely try to make it, cheers!
from the pic you posted you have Dayz side "steps" as well, show us more pics and we will tell you more!
Will do when I get home from work. The badge at the back says "Dayz Neo Series"
It's got the cool little touch screen that controls the air-con and cd player, kept be amused on the drive back as i tried to work out if there was a way of reducing the burn in my eyeballs from the brightness! got it in the end... as i was pulling up into adelaide ofcourse! :(
attessa costs 5k to fix.
get tyres exactly the same diameter........... definately.
well done on picking up your new hobby tho !
Do you guys think it'll be okay to put the current 215/50's in the front and get new 225/50's for the rear? The tyre width shouldn't matter to the rolling diameter should it?
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
