Kind of...
The profile number is actually a percentage of the tread width so theoreticaly it will, but like I said, the attessa system can handle a small amount of variation. I think it was Sydneykid that stated 5-10% so maybe PM him and ask where he got that info, and you should be able to calculate the difference from there.
But no, the width itself won't make a difference.
Do you guys think it'll be okay to put the current 215/50's in the front and get new 225/50's for the rear? The tyre width shouldn't matter to the rolling diameter should it?
I suggest you get the same size tyres front and rear - the profile is calculated as a percentage of the width, so if you have different widths front and rear, but the same profile, then the rolling diameter will still be different, so you'll run into the same problems again.
eg 225/50/17 works out as:
225 = width of the tyre tread surface in millimetres,
50 = 50 percent of the tyre width
17 = made to fit a 17" diameter wheel.
Basically, and changes you make towards going to a wider or narrower tyre, or lower or higher profile, they all affect the total rolling diameter of the wheel and tyre combo...
I see, i'll look for the appropriate ones then.
Are these calculations right though?
Front 215/50 = 107.5
with either (rears)
A. 225/50 = 112.5
B. 235/45 = 105.75
If I go with A, the percentage is 107.5/112.5 = approx. 5% diff.
If I go with B, the percentage is 105.75/107.5 = approx. 2% diff.
Side question... what's the funny vibration/fart it does when i turn the engine off? It's like a vibration lasting a second, feels weird. Feels like it's coming from the drive or something.
Edited by webng
Apparently this happens if your 50/50 torque split button is on.Mines definitely OFF though, strange...
definately ! the roads into and out of Strathalbyn were "nicely" paced :P
good to see my Stag kept up power wise with the best of them - great to know :D handled brilliantly thru the faster twists as well
definately ! the roads into and out of Strathalbyn were "nicely" paced :ninja:
good to see my Stag kept up power wise with the best of them - great to know :thumbsup: handled brilliantly thru the faster twists as well
It looked and sounded GREAT from the back for sure!
  • 4 weeks later...
Hello all from across the pond!
I'm researching a problem that I'm having over here in the UK, and was wondering if you managed to find a solution to your issue with the 4WD light coming on.
I have a Stagea over here, exhibiting exactly the same symptoms. All 4 tyres are the same, all replaced at the same time, but I get the slight juddering while driving along at constant speed occasionally.
Sometimes it can go for weeks without happening, sometimes as soon as I get to the end of my road it'll start.
If I turn it off and on (Microsoft Reboot Engineer tactics) it works fine after that (sometimes).
Did you find a fix for the problem at all?
Have you checked your Attessa fluids? Drivers side, in the boot, in the little parcel shelf like bit. There is the atessa resevoir in there. You can use Auto transmission fluid to top up.
My juddering was rectified after i changed the tyres so the rolling dimensions were very very close.
under the front passenger seat is a cable that runs from the attessa computer to the ecu, I think.
mine was 'perforated' when we installed a cdstacker under the seat. 4wd flashed randomly and had me rather stressed.
check the cable for abrasions, check the fluid too, might require a bleed ?
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
