OH no my plenum
Guest KILLER-T
Here is one for everyone to have a good laugh at first i have a intercooler that cracks every 2nd week now that i have that sorted my new plenum is lifting off the runners 3 hours on the dyno and im not ****ing happy im sick to death of forkin out my hard earned $$$$ for crap i cant wait untill the morning so i can call this ****er who made it.
And thats the end of my raving for now man im am sooooo ****in pissed off
https://www.sau.com.au/forums/topic/17429-oh-no-my-plenum/
F#&K dude, this was one of the very cold company plenums correct? on an exchange basis? i say get them to refund your money, and look into a perforamz one or A philamantra plenum (he is the guy off Performance forums that does rb plenums) I have seen his work in the flesh, and its very nice work. they have variable length trumpets inside the plenum and 5 litre+ capacity.
https://www.sau.com.au/forums/topic/17429-oh-no-my-plenum/#findComment-361012
for fu**s sake adam,
u must be so fed up with this happening all over again...
u even pay top dollar for shit, and it has problems... well i don't need to say "don't take any shit" if they try make excuses cause i know u won't. good luck with it
https://www.sau.com.au/forums/topic/17429-oh-no-my-plenum/#findComment-361211
Guest KILLER-T
Well i called the place today and he said take it off send it back to them and they will fix which i thaught was good but then he wanted me to pay the postage on it.So after a few choice words with this turd i rang QLD consumer protection and they told me that the company that made the plenum will have to cover all the costs for everything inc taking the plenum off the car and putting it back on.So i call company again and tell them that consumer protection said that he will ware the cost of everything if the plenum is faulty.After that he started raving crap about him knowing his rites and blah blah blah so i think consumer protection will have to sort this one out.
Mayhem By lifting of the runners its pulled away from the runner its hard to explain but you are welcome to come have a look
https://www.sau.com.au/forums/topic/17429-oh-no-my-plenum/#findComment-361903
Adam talk directly with mick,if he is still there,i had a problem with a cooler from them thet was full of filings and them fixed it up and payed frieght.Also if you payed for this product by credit card the transaction is counted as happened in WA and he would have to contest any action by consumer affairs in WA costing him at least 1 airfare to WA,much cheaper for him to pay frieght.
https://www.sau.com.au/forums/topic/17429-oh-no-my-plenum/#findComment-362480
    • Or get a guy in his early fiftys to do it. A single good "oof" and about two cracks from his lower back is about the right tightness...
    • It's impossible to convey what it will feel like to get the right torque. But you can develop a feel for it. A 900mm breaker bar is.....f**king huge. I only use a normal ~400mm one. But with 900mm being very nearly a metre, and the right torque being in the order of 100Nm, then you're going to need a bit over 100N of force, which is about 10 kg. So if you practice using the bar pulling up, instead of pushing down, then it will be about the same effort as lifting a 10kg bucket of water. That's what the pressure against your fingers should feel like. Ish. If you use a more typical length breaker, then it's about twice that. So a good 20 litre bucket, or a little bit more.
    • Also, if anyone has a torque wrench around Williams Landing area and can lend it to me for like 5 mins - I got 4 bottles of Furphy left and I’ll throw that in with a Happy meal 😂
    • So today I decided to bleed my brake fluid, which meant to the wheels came off the car at my garage for the first time. I only had a 90cm breaker bar with me and I noticed that some 1 or 2 lug nuts were a bit hard to get loose (from when the shop did the coilovers) Now.... when it came to putting them back on, I didn't want to put all my weight and overtighten them. So I hand tightened as much as possible and then put normal pressure on the edge of the breaker bar and tightened it until I couldn't turn it anymore without putting in an effort. Do you think that is tight enough? Or is that still too tight?  They are tighter than finger tight. Last thing I want is to have them strip or warp sh*t. But hard times mean I can't just go down to Supercheap and get a torque wrench 🥺
    • Dunno what to tell you, when I look at it on Consult I can see this warmup timing map kicking in around 40C coolant temp and it sticks around for a while:  At part throttle on the normal base timing map it peaks around ~43 degrees of timing or something like that, this warmup timing map drops it to like 12-15 degrees.
