After my tune, first tank: 303.3km/52L.
Second tank is looking slightly better. Most of my driving is peak hour with moderate stop start traffic.
HKS 2535, Bosch 040, Denso 550cc injectors, Link ECU, turbo back exhaust, pod, cooler. I think its making around 190rwkw on 1.1bar.
Not enough k's for my liking =|
https://www.sau.com.au/forums/topic/174292-fuel-eco/page/2/#findComment-3205535
  • Replies 78
Posted Images
The RB30DET in the R31 gets a consistant 12.5L/100 around town with a/c on and some fanging, around 11.5L/100 with a/c off.
On freeway it only does 10.0L/100, dissapointing really, I think mainly due to cruising RPM at high freeway speeds at 3000rpm, due to short 3.7:1 diff ratio.
Needs a 6 speed box and rpm dropped down to around 1500rpm, then it should be doing around 7L/100km. (Based on the fact my RB30ET (less efficient) can do 10.0L/100 on freeway with a/c on - has taller diff ratio)
Could go taller diff ratio, but will loose some snapiness of the lower gears.
Also would improve if boost afr mixtures were a little leaner as well.
https://www.sau.com.au/forums/topic/174292-fuel-eco/page/2/#findComment-3205784
R34 GTT 1998
i got 15L/100 6.5km per 1 litre...... most city driving...lots of traffic light about 10km of highway..
it too much... i thinking to change O2 sensor.... hope it would help... injector was cleaned 3 time afteri bought this car about 2mth ago....
the previews owner were never f%$kn serviced this car... imported whe 45000 sold to me at 73000km f#$k ill never deal with that sort of guys
https://www.sau.com.au/forums/topic/174292-fuel-eco/page/2/#findComment-3206233
i just got 480km outta about 45L of shell v-power.
Mildly modded 33 gts-t with PFC
That was on the freeway though (syd to central vic)
Only got 400 outta nearly a full tank of BP ultimate.....but found out when i filled up at the shell that o2 feed back was switched off :thumbsup: my bad
https://www.sau.com.au/forums/topic/174292-fuel-eco/page/2/#findComment-3207258
Hey Guys great excel table i might have to make one myself,
I just got my new personal best due to the great drift weather.
ohh i mean great rainy weather i only just got 280Km from 55L fill YES whoot
hey zennon what mods do you have to get 568km, you must have i light foot and a great tuner
https://www.sau.com.au/forums/topic/174292-fuel-eco/page/2/#findComment-3209201
haha, i must admit i was impressed but didn't really know quite how good it was until now (compared with others)
has the normal little things: fmic, pod, 3" turbo back exhaust, 11psi, etc (for more info)
the guy i bought it from told me it had gtr fuel pump and remapped ecu but who knows...
he also told me it had a heavy duty brass button clutch which was a complete lie
https://www.sau.com.au/forums/topic/174292-fuel-eco/page/2/#findComment-3210041
I feel less lonely now that someone else has the same economy as me haha
What mods do u have?
I did 318km on 51L for my last fill.
https://www.sau.com.au/forums/topic/174292-fuel-eco/page/2/#findComment-3210395
The old RB20DET @ 1bar, stock ecu, stock airbox, fmic & 3" exhaust making 164rwkw used to consistently crack 470km's to 50-52litres.
The RB30DET is a touch heavier on fuel and usually see's 430-450km's to a tank but I do tend to give it a little more stick as it loves off idle acceleration. :domokun:
A little bit of open road 100km/h cruising and fuel economy pushes easily over 500km's to a tank.
Its always been reasonable on fuel. It appears some cars are some aren't. Possibly driving style when you are driving slow/cruising? I've found I see a noticable improvement in economy shifting up around 2000-2500rpm absolute max in every gear even if it means using a little more throttle; get it in to top gear asap. Drop some nulon fuel system cleaner in it every 10,000km's and thats pretty much all I do.
https://www.sau.com.au/forums/topic/174292-fuel-eco/page/2/#findComment-3210875
my r33 running 10psi - 221kw (highway) is better than a guy i know who bought nearly stock r33! dunno if there is anything wrong with his car...... just changed my fuel filter too. plus tighned my intercooler piping which is always good because loose pipes ect. will make you car idle higher... more fuel consuption. And dont hit the accelerater too hard, cause when i open her up u can see the fuel gauge needle drop!
https://www.sau.com.au/forums/topic/174292-fuel-eco/page/2/#findComment-3212669
i have a very near stock R32 GTS4 rb20det, its got i nismo air filter in standard box and a Split dump pipe, but in saying that i have 157kw at the wheels and still running stock 8psi
also i did a freak run, i got 407km from my last tank and filled 60L, mostly highway with full car!!
weird if you ask me cause i thrashed it with an extra 250kg extra
https://www.sau.com.au/forums/topic/174292-fuel-eco/page/2/#findComment-3220880
normaly 440 odd on my r32 gtst. Normaly Driving....neva under 100kms each quater marking (evn thou it moves un evenly)
had even got 630 kms doin a highway trip...53.8 liters used, my girl friend was driving...my heavier foot would be able to match those numbers
haha - yeah same boat as me
https://www.sau.com.au/forums/topic/174292-fuel-eco/page/2/#findComment-3221277
  • 3 weeks later...
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
