After much searching, we decided to purchase a Nissan Stagea as our family car, after our son was born a few weeks ago.
There weren't any Stagea's with the specs we wanted, available in Perth, so we just got one transported over from VIC.
It is a Jan 1999 Nissan Stagea with the straight Neo 6 engine it - 76000 k's on the clock - supposodly a grade 4b at the auctions. It presents very well.
It has had an RACV check done on it and all passed ok, and had a little bit of work done also (break pads, park lights - noothing mech or electrical) to pass the roadworthy certificate in Vic.
It arrived yesterday via TNT, however on arrival at the depo in Perth, they advised they couldn't get the car started.
We just assumed it was a flat battery after being on the truck/train for 2 weeks. TNT said they tried starting it with jumper leads, but with no success. At home, we tried another battery in it and charged its own battery overnight, still with no success. It has petrol in it.
Unfortunately, it doesn't seem to be a simple flat battery problem. The dealer from whom it was purchased assures me that it was running when it was put on the truck in Vic, and the odo has 20km's more on it than when the RACV did their check - so it has driven in the last few weeks at least and I have to assume that it was running when it was given to transport by the dealer.
It was towed this morning to a mechanic (not a Nissan specialist however he is a motoring enthusiast and I have always found him to be excellent and through at his work) and he was unable to determine what was wrong with it, however it does not seem to be a 'mechanical' problem. So now the drama begins... what is wrong with it?
The motor is turning over freely and quickly when cranked with the starter motor, however it will not start - as if it has no spark. Cam belt/timing belt are all good. When the motor is turning over there is no recognition of engine revs on the dash tacho. What this may indicate I am unsure. I am probably going to get it towed to an auto electricians tomorrow, but I do not know of one that is familiar with these cars in Perth. There is no imobiliser fitted that I/or the dealer is aware of.
Any Stagea enthusiasts out there :) want to have a crack at what might be the issue and who we can take it to in Perth to get it looked at?
https://www.sau.com.au/forums/topic/174310-help-me-my-stagea-isnt-starting/
ALARM IMOBILISER?? FUEL ??
I agree, start with the obvious. Fuel is the first one, as they often get sent around close to empty - what does it say on the gauge?
It probably won't be an immobilizer as if it was the starter probably wouldn't be going around..
The next thing to check is the fuses - though again, if the starter motor is going around they should be OK.
Can you hear the fuel pump going?
Ian
hmm not sure of any obvious reason.
Maybe take it to Ken at Hyperdrive, he knows his skylines....gtrken on these forums.
Did they check the spark? put a plug in a coil that isn't on the motor and turn it over, see if you get a spark? Do you have fuel pressure (put a guage on it)? Does it have compression?
I vote fuel pump too. Mechanic should have picked that up though.
One possibility I guess is a fried ECU, would it still crank then? Someone here will know. If it is, it probably happened when it was unloaded and wouldn't start, bad jump starting technique (incorrect polarity when hooking up the jumper leads)
I hope you find a simple solution!
Yeah it will still crank with a dead ECU or wiring problems to the plugs/cas. the cranking just requires 12v at the starter motor.
Thats why you need to check for spark....
old, simple rule.....motor needs fuel, spark and compression to start.
Pullout the "Coin" tray on the RHS of the column. There may be a blown fuse in there. Somewhere ther is a diagram on this forum of the fuses and what they are for. If it wont start it is either no spark or no fuel.
My Stag came in with a long wire going nowhere from the fuel pump fuse. I have an R30 with a secret cut out switch.
Nissan engines do not fail to start.
http://www.skylinesaustralia.com/forums/in...howtopic=141454
This thread should help you out a bit.
There are a few work shops south of the river, Xspeed is one that I would recommend. They diagnosed my broken manifold stud as soon as they heard the awful ticking sound... I was pretty panicked about a ticking motor!!
Sometimes if the battery has been jumped backwards it will fry the main fuse - saving (hopefully) you ECU & other electronics. Check in the main fuse box in the engine bay. Also check under the positive battery cover on the terminal itself, occasionally they are built in there instead.
Check the keyway hasn't broken off on the end of the exhaust cam driving your crank angle sensor. Have seen that happen a couple of times after a service (myself included :D )
Apart from that, as Duncan said; fuel, spark & compression
i'd be checking fuel pump and coilpack ignitor (if the s2 have one) which is on the coilpack cover near the back from memory.
fuel pump is pretty easy to hear if u listen when u turn the ignition on or give me a pm and ill show u what wire u need to put power to, to trigger the pump. check if spark is working by removing the plugs and coilpacks and holding the coilpacks and plugs all installed but out of engine close to the rocker covers and crank it over and watch if they spark when cranking.
also check the injectors are firing by removing the CAS on the front of the exhuast cam and spin the shaft around with ignition on and u will hear the injectors clicking as u spin it around.
as said also check fuses for fuel pump, ecu, etc. in the engine bay and under the dash
Edited by overpowered
Hello All - thanks for all of your responses. Took thevehicle to a mechanic that deals with a lot of imports and he replaced the plugs as he said that although they were sparking they were "flooded" which, when questioned he said were carboned up and probably wer not providing enough spark - Anyways, new plugs and she goes. Hope all is well from here on in. Thanks for all of your input
If they were carboned up that bad, you may want to get a decent tune asap, and also look into replacing your exhaust O2 sensor. That is not a common fault AFAIK with the RB and it may need a little further investigation to make sure it doesn't happen again.
Good luck with it anyway, and welcome to the family!
A littel while ago i pulled up at a tool booth payed my money and proceded to take off i only got about 20m when the engine cut out. what i found was it had blown the rubber hose off the turbo. While i could crank the engine over it would not start until i pushed the rubber hose back on. This may not be the problum but it is an esey fix if it is.
Mine isnt starting now :)
I put new speakers in the rear doors today. Started it up and drove it into the garage.
Went to drive it an hour later, turns over but no start.
Can hear fuel pump and all fuses light up with test light.
Will go check the spark now.
Any other ideas??
    • Hey everyone, just wanted to let you know about an app I use to track the modifications, repairs, servicing etc I do to my R33 GTR. You might like to use it as well. I'm biased because my son just wrote and released it! But I think you might find it useful to... https://trackmymods.com
    • Hey everyone, been on here for a while, but never introduced myself before. 1st import was a R32 GTS Type M, then R33 GTS, now R33 GTR - each one sold to help pay for the next one. Over the years my son has seen me modify and do changes to my imports and was one of the reasons for him to build an app for car enthusiasts like us. (He can only afford a 2007 Honda at the moment, but he'll get there!) Anyway, bit of a proud Dad moment as he's released an app that I use and you all might like to as well. https://trackmymods.com
    • It will sound tragic and you wished you didn't have 1x exhaust per turbo. There's a reason why most S55 owners change to a single mid pipe.
    • Echo the comments about the well preserved condition it's in. It has the aero bumper too for extra points. Nice car, and please keep it like that! 🙂
    • 1. There are no real performance benefits. It sounds different, and as the pipes are not as large diameter you can claw back some undercar clearance or run lower (if that's your thing). 2. Twin pipes, offering exactly the same cross sectional area as a single pipe** will have higher pressure drop - so will not flow as well. That's because there is more surface area of wall per cross sectional pipe area, hence more frictional losses. ** But of course, it is almost impossible to get 2 pipes that are exactly the same XS area as a given typical single pipe. eg, 2x2" is not the same as 1x 3", although it is close. If the 2x pipes add up to less XS area than the single - it will just be flat out worse. If the 2x pipes add up to a bit more than the single, then it might come out as a wash. If the 2x pipes are substantially more XS area than the single, then it will probably flow a little better. 3. No. Why would there be? What have cats got to do with boost creep?*** ***But for f**ks' sake, please run a cat. 4. If you want.
