Last weekend i decided to tidy up some wiring under the dash of my R33 GTST S2 so i thought i would do the safe thing and disconnect the negative of my battery..it was disconnected for proberly 2 hrs but ever since i connected it back up my transmission is crap.
Now when i take off in drive from 1st to 2nd it near jolts your head off..from 2nd to 3rd it just won't change unless i lift my foot off the throttle a bit and the same for 3rd to 4th, even changing gears manually it does the same..i've done a search and found some members posts that have had sort of the same problem tried and checked all the surggestion made but no luck.
Fluid level is fine, theres no difference between a warm or cold transmission....would the ecu may have reset while i had the battery disconnected and now its not controlling gear changes like it should.
any advise or ideas would be great...thanks guys and girls
https://www.sau.com.au/forums/topic/174311-auto-transmission-problem/
battery shouldnt have affected it, what did you do when you tidied up the wiring ? possibly you have knocked something loose. Check the Auto ecu behind the drivers kick panel, unplug and replug it and any other plug you might have touched inadvertently, might just be a loose connection from the ECU to the Auto ECU, speed signal eg
Edited by chook
it was just a simple tidy up didnt unplug anything just zip tired and secure wires hanging down...but i will get back under and check......thanks chook
well i checked everything all looks fine...really strange and giving me the poohs...to get it to change from 2nd to 3rd and 3rd to 4th i have to rev it out to 3500 to 4000 rpm or lift my foot off the throttle each time i get a shit gear change.
would this be a job for an auto electrician or a transmission mechanic?
  • 3 weeks later...
Problem fixed it was the TPS got all out of whack got me stumped how..lucky i found a pretty cluey tranny mechanic who sorted it out and also done a mod to my tranny its perfect now
What was the mod that he did?
similar to a shift kit... just drilled out the oil holes in the valve body...gear change is more responsive but not to harsh
Interesting. Never heard of this before. So your gear changes are quicker and sharper, but it doesnt have the harshness of smacking into gear like a proper shift kit?
  • 9 years later...
would really like details on this, anyone ever work out just what was drilled and how big??
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
    • I'm not sure where you are, but United Terrey Hills has E85.
