Out of the 32 GTR, 33GTR and 34GT T with no expense a problem which would create the best car for track and occasional drag.
please post opinions backed with facts! Cheers.
ps, sorry i posted twice. should of been in here origionally
https://www.sau.com.au/forums/topic/174314-skyline-with-greatest-potential/
no expense? gtr will be quickest except maybe for drag. Ultimately the 4wd traction is worth more than the weight penalty.
But in the real world with real budgets its not hard to get a gtst to keep up with a gtr, cheaper to get power out of a gtst and it is lighter in the first place. They have the same suspension setups/potential and can run nice big tyres for traction
Can you strip the car? How far can you go. Is it to be a daily driver?
I would say R32 GTR. Cheapest. Has all the ticks for the building blocks of a good car.
Strip as much weight out of it as possible. Carbon doors, keep alloy bonnet and guards. Throw a strong RB26 in there with a solid 380awkws from something like KHS 2530s running 1.5bar. Throw a strong 5spd with close ratios in it. Also beef up the transfer case
Then wire up the R33 ATTESSA system/sensors/computer so that the thing has a little more smarts and controls the AWD system a bit better.
Then throw some nice suspension at it, with some nice 355mm brakes on the front. That is the shopping list i have for an R32 GTR, but simply cant afford. It woudl cost a small fortune. But would run 10 secon qtr miles and if driven well would be a very quick track car. And if you keep the aircon and basic interior, and colour code all the carbon could still be used reasonable day to day as a road car.
So do you think that a GTST/ GTT could be made faster than a GTR for the drag strip? interested really because some of the faster cars wol;d have very little pressure on the front wheels anyway wouldn't they?
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
