Get every dollar out of the stock one.
its not worth taking the risk cos with this view, it might srsly end up costing you more dollars than you bargained for. If your going to do at some point, why not just do it now, cos at 280 rwhp, you'd be pretty much close to maxing it up. Sometimes you cant even notice have much it is leaning out. i'd say just change it, before you do long term damage
Edited by moonus
As rednecks would say 'don'ts fix it till it's brokes'
But seriously should be fine, and you don't want to put fuel pump in unless you really have to... It's a stinky c**t of job.
Buy a fuel pressure gauge only $69 (defi style) from just jap for fuel pump insurance + you can rice your cabin up more.
I reckon change it. Its not worth you taking the risk till it dies, it will leave you strandard in the middle of no where.
If you have the cash just buy it, there is no harm in changing it. It may last you another year, or maybe it will last another day. Who's to say when it will go?
At least with a new one, you will know its got a long life a head of it, and its not going to clonk out any time soon.
If your planning on getting more power out of it, why not upgrade it. The stock one didnt cost you anything anyways..
You could pick up a replacement pump, like a BOSCH 040 cheap enough.
Buy a fuel pressure gauge only $69 (defi style)...
But $70 is like half the price of a fuel pump. Later on if he buys another fuel pump, when it does die, it will cost him more in the long run. Might as well spend the cash and upgrade now..
Just my thoughts!.. :D
Thanks,
Abu
Edited by abu
Thanks,
Abu
Where are these $140 fuel pumps you speak of... my genuine bosch cost $220 delivered. A fuel pressure gauge is a good idea all the same, as if fuel pressure drops the afr's lean out and cause damage.
Many cheap after market fuel pumps break or seize shortly after installation due to poor installation, factory faults with pumps, and especailly with 040's the bottom filter screen sucks up crap and reduces possible flow which burns out the pump.
Thanks,
Abu
By your reasoning you should sell your r32 and get a new car because it could die at any time.
keep the stock fuel pump, its still working, no reason to change it and spend money now rather than later.
If it dies in the future, change it then. It'll take you 2 hours max, and usually they slowly die rather than just stopping working all of a sudden, so you should have plenty on notice before it goes.
i say stick with your stock pump untill it starts to die, or you decide to do more upgrading. atleast you know it is working. you may get a new pump and it may be faulty straight out of the box, so you would be driving around thinking everything is fine and then end up causing more damage. if you do get a new pump installed i would put it back on the dyno to see if the mixtures have been affected. ucd15r33 put his car on the dyno 2 days after a new fuel pump and the mixtures went from in the 13's to low 10's, so upgrading his pump was a good thing. but if your pump is good and the new one is dodgy it could go the other way.
I didnt say $70 was half the price of a fuel pump, I said its like half he price. Although I have bought a original BOSCH 040 new in the past for $160, which for arguments sake is almost double $70..
You could spend $180 and get a BOSCH 040 brand new, theres one on calaisturbo at the moment. Original BOSCH too, with receipt.
All I was saying was if your after a bit more reliability, and peace of mind you might as well change it. Its a matter of $200 max and about 2 hours work. He obviously has some concerns, hence this thread?
The stock fuel pump would be a least what, 14 years old by now?
Thanks,
Abu
Not even going to justify that with an answer.
But according to your signature you seemed to have recently upgraded to GTR fuel pump from standard?
Any reason for that, since your car is only making 155RWKW, which is plenty for the standard fuel pump to handle..
Just curoius.
Thanks,
Abu
Edited by abu
Agreed
first of all what car is it, i may have missed something, if it is a GTR then it should be fine, however if not i would change it, yes you have had the car tuned and all was good but i can tell you the harder you push the pump the faster they fail and you wont notice it leaning out all that much until it is too late, changing a fuel pump is an easy job especially in a nissan most local mechanic will only charge you around $50-80 or you can do it your self in a half hour. the cost of a new pump is not much and is good insurance
Just curoius.
Thanks,
Abu
Yeah fair enough, I guess I was just trying to make a point that you can't always go around fixing things just because they might break in the future.
My fuel pump (r32 gtst) lasted 14 years and 175,000kms. I discovered my car was running lean so i replaced it with a GTR pump.
So IMHO if you know your pump is providing enough fuel, its not worth replacing it.
I guess if you want the extra peace of mind, upgrade it. But make sure you get it dynoed after to ensure the new pump is operating as expected.
Cheers,
Rhett
When my stock pump started to die it went from nice solid afr's to running dangerously lean within 6months.
If its old, high km's and showing that its a little lazy.. Replace it; not worth the ringlands.
Your tuner will know what you pump is good for and if its lazy or not.
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
