hey guys after cleaning my aac valve at around 4000rpm i get a miss fire. its like its hitting a rev limiter or something. i used to get a weird jolt after installing the fmic but thought that was normal. now its just loses power. any help would be much appreciated. thanks in advance.
https://www.sau.com.au/forums/topic/174329-miss-fire-at-around-4000rpm/
chances are the installation of the cooler has reduced the temperature of the intake charge, which has the effect of increasing the density of the mixture in the combustion chamber and now your 10+ year old coil packs are having trouble igniting this mixture. any increase in boost will also add to this problem..
basically your best bet is to wind back the boost a bit and go for a drive, if the misfire is gone, this most likely the cause of your problem, the easiest thing to do would be to pick up a second hand pair of coils from the forums, however these will also be time bombs waiting to go.
the best option would be to pick up a pair of split fire coil packs, i believe these are about $500..
i have also heard of people having limited success 'taping' there coil packs up to provide better insulation, and it also never goes astray giving the earths near where the thermostat housing is a good clean, as well as the main earthing straps between the engine and the chassis a clean too..
there is alot of information around the forums on this problem so search is your friend :)
hope this information helps :blush:
its just weird how it got worse after i took off the aac valve for cleaning. maybe just bad timimng. ill look into these things. thanks alot :)
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
