Here are some pictures from my weekend (24/07/07).
This time i headed out with Keita to f*kushima again but not to Ebisu, rather another similar style course called S.S. Park. SS Park is smaller than Ebisu circuit but still boasts 3 seperate circuits (including a gravel course and soon to be built R.C. Course). It is smaller albeit maybe a little more professional than Ebisu. Though they really can't be compared, both have goo and points. Again with my partner in crime Keita, we went out to have a look and Keita entered the Competition held on the day. He didn't win, but he did do better than the poor guy in the Silvia... I was also pleased to see so many people with their children their enjoying the day and having fun. Very different from what i've seen back in Aus. Finally i wanna say a big thanks to Keita again and best of luck at Nikko!
Please enjoy,
Peter
Beautiful S15, which went on to totally destroy its front end only a few laps later...
Sexy S13!!
Nice is the best i can come up with..
This one too... (nice!)
A 4 door going for it
This is what happens when you play with your fuel filler/tank area yourself...
S14 Powah!!
For the 4 door boys..
Locked...
These days really bring the families too...
Edited by Poida
hahah, no Delica space saver action this time hehe, but yeah. I'll get round to upping more videos from all events one day.. One day... .. .. .. ...
awesome pics! bad luck on the s13 bursting into flames...what happened?
S13 i think played with the fuel tank or pump or something. It wasn't clear, but he did something at home and mustn't have done it right and it went up in smoke. Was quite sad to see..
The after result =
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
