  • Replies 951
i do that. When you're rushed you always forget something.. and it's usually peeing!!!
pity it's already sold out, I would have loved the Winton day part of the trip!
The stupid thing was, I had it right there sitting with all my stuff to take.. *hits head*
I'm not sure if most of us are doing Winton?
Look mexicans are bringing there power house cars out to try and beat us .ahahahahahahhahhahahahaha
So if we're mexicans... that makes you America... well known for 3ton cars and arses...
Think VIC stands a good chance of pwnage...
GO VIC!!!
GO VIC!!!
If you are going to be doing all this flaming better come to DECA and not be a piking Mexican!
hey hey... theres no flaming... theres just rebuttle and defence of this lovely nation we call Mexico
MIGHT come... if not to help out with flags and stuff if its required then to have a nosey and spectate if its allowed :)
I think you should not be weak sauce and come and say Hi!!
I need to meet the person who photo chopped me *glares*
p.s I can finally post *kicks internet*
if i have my new car by then 4 sure.
lets me check my calendar...
Aug 7 im on Night Shift which is 11pm to 7am so dont think it will happen... unless i can get the days off.
if it was the week before would be all good cause i have a rostered week off.
Is it just the 7th??
just saw the first post... dunno where i got 7th from
25th im working days but could quite easily get someone to fill in... so if i get my car in the next few weeks i will come for sure.
face mask on for protection... i dont have a slap friendly face :)
You have to get thru NSW first to pick up your car :)
I wont Slap you.....................much :)
this is steve's way of telling you he's not coming to winton.... muhahahahaha.
HAHAHAHAHA - sif.
:yes:
Not that im expecting anyone to drop out, but ive put up a reserve list.......just incase
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
